  • July 13, 2025, 06:51:08 PM
Author Topic: Pretty Darn Good Muffler  (Read 3710 times)
« on: July 13, 2012, 01:31:25 PM »
The OS E-3030 muffler that comes with the 40-46LA weighs 2.6 oz.  With some modifications, it can be reduced to 1.6 oz.  That's a significant savings!
They made it much too thick!  So get cracking with the Dremel sanding drum.  Reduce material inside and outside to less than 3/32" thick, including removing those useless cooling fins and the "stinger".  Cut the main piece shorter. Remove the baffle, cut the screw down and re-thread 6-32.  Fit the two halves for a tight slip fit and epoxy together with JB Weld.  A bit of polishing and you have a much lighter muffler.
Offline kenneth cook
Re: Pretty Darn Good Muffler
« Reply #1 on: July 13, 2012, 04:30:41 PM »
           Floyd, I like your thinking. That cone inside is a useless POS. I never had it do anything but overheat the engine and cause complication and believe me I tried to make it work. The outlet is too small and need to be opened as wide as possible as well.  Ken
Offline dennis lipsett
« Reply #2 on: July 13, 2012, 06:14:37 PM »
I usually try and use a tongue muffler. At 1/2 ounce it's hard to beat.
Dennis
Offline Paul Wood
« Reply #3 on: July 13, 2012, 06:42:58 PM »
That baffle is only good for the idle mode.  I pulled one out for an R/C pylon race.  It ran great, but would not idle at all.  Not needed for U/C except maybe scale events.
« Reply #4 on: July 14, 2012, 12:43:48 PM »
   I don't know how it works on this particular muffler. But the baffle is absolutely critical for the E2030 muffler on the 20/25FP and 25LA.
« Reply #5 on: July 14, 2012, 12:48:41 PM »
Hi Brett,
The way the E2030 muffler works might just be one of those strange phenomenon that occurs every couple of millennium.  But it does work as advertised when used as part of the complete package!
BIG Bear
RNMM/AMM
Offline Chris Wilson
« Reply #6 on: July 16, 2012, 08:55:08 PM »
Dennis
Sure the weight is hard to beat but to me tongue mufflers are simply perforated strainers designed to spray oil and debris 180º.
MAAA AUS 73427
« Reply #7 on: July 16, 2012, 10:07:09 PM »
Tongue mufflers are at best only good for reducing the bark of the engine and your right about the spray. But tube mufflers are just as offensive in their ability to make a mess. Rear exhaust and venting under the model seems to be the best solution,and electric is the hands down winner for clean sanitary running.
« Reply #8 on: July 16, 2012, 10:32:51 PM »
 How many sanding drums did you go through to get there Floyd? Neat idea but cosmetically speaking it's still a BIG muffler. Something to keep in mind though.
« Reply #9 on: July 16, 2012, 10:38:58 PM »
Hey Dennis,
                    the thing I have against tongue mufflers is that they are not an exhaust system as such.
A 'system' directs waste gas, oil, heat and noise away from where it is not wanted and some systems require noise suppression and some don't.
Tongues dive straight into an attempt at noise suppression at the expense of all else and try and justify their existence on being light in weight.
But, yes I agree with the rearward exhaust mantra - every well designed vehicle follows suit and for a good reason.
Cheers.
MAAA AUS 73427
« Reply #10 on: July 17, 2012, 08:02:51 AM »
Hey Dennis,
Cheers.
Practically speaking if there was an efficient muffler for c/L no one would use it simply because of size and weight. Aluminum is not a real good dampening material for noise, the choice for most is light steel and sufficient volume to slow everything down before it exits the stinger.
Bob Davis at Davis Model Products supplied some of the most efficient German made mufflers to the r/c community and had very little luck with them because of the same objections as the C/L crowd. That said Europeans fly large gas burning models with no more noise then the family sedan because they have to comply with strict noise restrictions. most have very well designed steel mufflers with efficient baffles in them. Regretably efficiency is probably not pretty on a stunt model.
What would I judge as efficient. When you can fly in a populated area and not be chased  because your a noise nuisance.
« Reply #11 on: July 17, 2012, 03:24:10 PM »
HA!  Yes, a lot of powdered aluminum ended up on my workbench!   The Dremel sanding drum actually is pretty tough and cuts metal nicely.
Of course, the ultimate solution to exhaust goo is rear exhaust engine and a pipe or a long muffler.  I have several of those, but the OS46 spits out the side.
I might someday be a fan of tongue mufflers, but they are all too short!  Hey, a longer one would get the goo away, but they are just short enough to spread oil all over!
FLOYD
Offline Balsa Butcher
  • High Desert Flier
« Reply #12 on: July 17, 2012, 04:39:25 PM »
Great idea Floyd. I have half-heartedly done this to a few of my OS Mufflers but this shows how to do it right.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #13 on: July 17, 2012, 07:21:29 PM »
Slimline mufflers had the right idea about length when they made their tongue mufflers. But the rest of it wasn't up to standards of efficiency
Offline Kim Mortimore
« Reply #14 on: July 17, 2012, 08:33:23 PM »
The results seen by myself and those I fly with are significantly better with the E3030 than with aftermarket, unbaffled tube mufflers on the LA46.  However, we haven't tested debaffled E3030s.  In either case, there is a lot of weight you take off it.
Kim Mortimore
Santa Clara, CA
« Reply #15 on: July 17, 2012, 08:41:01 PM »
I think that pure exhaust noise is somewhat overshadowed by prop noise and this muddies the waters in regards to what is heard as an 'efficient' muffler.
I have seen straight through all aluminium mufflers that work on the absorption principle wrapped with glass matting that are very good at noise suppression - the only down side is having to repack them from time to time . If you want a really quiet and simple system then extend a perforated pipe from your exhaust, wrap it in fine glass cloth and slide a covering tube over that - no need to seal off the ends of the outside tube if it is a good tight fit.
Light, easy to make and has very little back pressure, but as I said you will have to repack it every now and then due the weight gain from oil absorption.
The Davis muffler, was that the reverse flow three piece cast job that emulated the BMW motorcycle design? Totally over engineered in my opinion if it is what I am thinking of!
No matter how quiet your model ends up, if you fly control line in continuous cyclic circles there will always be the repeated Doppler effect that will drive people nuts. The human mind simply hates the same noise rising and falling over and over again (this effect is the basis of most alarm systems) no matter how low the Db reading is.
MAAA AUS 73427
« Reply #16 on: July 17, 2012, 10:27:33 PM »
None of the Davis mufflers were cast.
Dennis
« Reply #17 on: July 18, 2012, 12:14:08 AM »
Dennis
Hmm, must have been one called the "Snuffler" then.
Thanks.
MAAA AUS 73427
