We've seen a few, mostly on RSM Ringmasters. The way I see it, if you put a bigger & heavier engine on it, it won't be 32 oz anymore, so I'd say yes. But I'd also think seriously about getting one of the new Magnum XLS .25's and putting a venturi in it. One reason is that the parts support, engine availability, and price seems to be quite a bit better. Look at Hobby King...ASP is the same engine.
http://www.hobbyking.com/hobbyking/store/__25465__ASP_S25A_Two_Stroke_Glow_Engine.htmlI have questions! What is your altitude, typical temperatures, and wind? Are you ok with running some extra nitro, maybe 20%? Will you work hard to optimize the propeller, or just use what you can get at the LHS? Will you adjust your line length for this model, or will you use the same lines for multiple planes? Can you do the whole pattern, or not? FWIW, really good fliers (not me!) can get a plane through the pattern (and make it look good) with less engine than most of us. That sort of stuff will make a lot of difference.
