  • July 12, 2025, 02:48:10 AM
Author Topic: Please help ID this  (Read 1402 times)
Offline Peter Nevai
    • C3EL
Please help ID this
« on: June 02, 2020, 04:56:01 PM »
Ok, once upon a time, back when I was younger and actually had a brain I ordered this Piston and Cylinder. I believe it is for a something larger than a 40 but smaller than a 60. I gather it is for an OS engine as that is all I have which this could possibly be for. Now I have a LA 46 and a VF 46 nothing else in my inventory that this could possibly fit. There is this nagging notion that seems to want to associate itself with this Item and that is it is defective seems like I remember getting a email concerning this after it was delivered. Something like "I neglected  to machine or cut something on this and if you send it back we will fix" But honestly that could be my twisted imagination. Anywho if this thing looks familiar to anyone please let me know. It could have come from Randy or god knows who else that makes aftermarket engine parts. Thanks. ??? ??? ???
Re: Please help ID this
« Reply #1 on: June 02, 2020, 05:32:01 PM »
    The slot for the alignment pin looks correct for an LA.46. The flange at the top of the cylinder looks pretty thick, and if it's a Brian Gardener ABC set for the LA.46, he only sold them with a new head because he didn't want to machine the flange as thin as the stock units are. I think Brian's sets came with a rod also??  Randy Smith made a fairly recent run of VF.46 ABC piston and liners, if I remember correctly. Either way, if you just measure common dimensions of known parts against these you should be able to figure it out. The I do not remember anyone putting out a "recall notice" on any of their P&L sets. If something wasn't machined correctly or completely, you might not be able to assemble them into an engine with out noticing something, so if you have enough parts you could just dry assemble things to see what does or does not fit. More or less a process of elimination. But the short answer is if you have a dial caliper and some known good parts for each engine, you should be able to figure this out in about 10 minutes.
  Good luck,
Offline Peter Nevai
    • C3EL
« Reply #2 on: June 02, 2020, 07:09:24 PM »
I think I figured it out. I found an old email from 2017 Randy sent me a piston and liner (has to be the one in the picture) which was missing a cut on the piston. This is supposed to be for the OS 46 VF that I have. Before I send it back though perhaps Randy will verify this.
« Reply #3 on: June 02, 2020, 11:13:46 PM »
This is  a pretty strange way your doing this ,  so I will answer this  here, NO that is not  one of mine, I did have a few 40 VF  AAC piston sleeve setups that did not have the cutout in them, and  I did  have  only  1  person that got one, He  told me  NO he  would not  send it back for replacement, He would cut the   piston himself.  The one you have  is  NOT one of mine, as they were  all  AAC... that is  aluminum sleeve setups. Yours  pictured  is  some  ABC  BRASS  setup for something.  If you want me to identify it for you, then I will be  happy to, Send it to me  for  ID
I did not  have  ANY  46  P/S  sets  that  were not  cut
Offline Peter Nevai
    • C3EL
« Reply #4 on: June 03, 2020, 12:21:24 AM »
Well if is not for the VF then could it be for the LA 46 ? At the time I ordered back plate Venturi and NVA for my 46 LA. As well as a Header for the VF.  This was back in 2017. Anyway I will continue this off line as I would really like to figure out what these are for without starting to tear engines apart.
« Reply #5 on: June 03, 2020, 09:19:55 AM »
I sold  backplates, Venturis  for the  LA 46  but  not  ABC piston sets, I sold VF headers  and  AAC sets  for   40  and  46,  If you want to know what it is, send it to me and I will  ID the  P/S  If it needs  a trim in the  piston, that is  easy to do I cannot tell  from a  picture, but it does  NOT  look like an  LA  Sleeve
Offline Peter Nevai
    • C3EL
« Reply #6 on: June 03, 2020, 11:27:45 AM »
Hi Randy, I will send it off to you and perhaps you can figure it out. I cannot see getting it from Brian Gardner in Australia and certainly cannot send it back should the piston need to be cut.
Offline Brian Gardner
« Reply #7 on: October 21, 2020, 07:15:18 AM »
I just stumbled across this post. It's not something of mine.
