  • July 08, 2025, 08:14:27 AM
Author Topic: Piped PA75, how much fuel?  (Read 2671 times)
Offline Chuck_Smith
« on: March 04, 2017, 10:24:18 AM »
Wondering what fuel consumption I should figure for a stunt run. I'm going with the K77 but I figure they should be close.
AMA 76478
Re: Piped PA75, how much fuel?
« Reply #1 on: March 04, 2017, 10:53:38 AM »
  I wouldn't assume that, but a PA75 generally uses around 8-8.5 ounces of 10%, using the definitive setup (David Fitzgerald's).
« Reply #2 on: March 04, 2017, 11:54:28 AM »
HI Chuck
Most people  use  7  7.5 ounces, 98% of most everyone using the  PA 75 run under  8 ounces, a few  use  8.5 ounces, will depend on plane size/drag  and  setup you go with, props  will also have some effect.
randy
Offline Chuck_Smith
« Reply #3 on: March 04, 2017, 06:08:18 PM »
HI Chuck
randy
Thanks Randy,
I'm really looking forward to flying this engine. The carbon fiber pipe is a work of art. Thanks for all the help!
Chuck
AMA 76478
Offline tom brightbill
« Reply #4 on: March 04, 2017, 06:59:06 PM »
Per Kaz's web site:
I use 10 to 15% nitro 20 to 22% all synthetic oil fuel
I use 230cc(8.1oz) tank for pipe and 180cc(6.4oz) tank for rear muffler.
You can use the same propeller and fuel as for PA75.
Tuned pipe 12.2 x 4.5 to 5.2 3B 9000 to 9600rpm
So far pipe length (plug to #1 baffle) is 455 to 460mm in my case
Rear muffler 12.0 x 5.2 to 6.0 3B 8700 to 9300rpm
Prop for rear muffler should be 0.5inch smaller than the prop for pipe.
You can determine the prop is too big for the engine if rpm increase in air.
Pipe create more power than the rear muffler.
When you use the rear muffler, I recommend "No baffle" muffler.
And It is highly recommended to use muffler pressure.
AMA 34849
Offline Chuck_Smith
« Reply #5 on: March 11, 2017, 07:24:52 AM »
I may have issues. The Evolution only has about 6 1/2 inches between the formers. Looks like I may have to build a custom tank to get 8 oz. in there. Ideas?
AMA 76478
« Reply #6 on: March 11, 2017, 09:17:32 AM »
Chuck, you're right, build the tank. I have the same situation with the K-77 powered Thunder Gazer that I'm building. I'm planning on having to make it 1.25 deep to get the extra volume (I need to find my notes just to make sure). You should be able to figure the location of the uniflow without too much trouble.
AMA 34849
Offline Chuck_Smith
« Reply #7 on: March 11, 2017, 10:26:24 AM »
Tom,
I'm thinking I can utilize the volume between the engine mounts and have plenty of fuel. This would be an easy mod to an existing 6 oz. tank. I just need to build the doghouses and then attach them after creating the openings in the tank.  I need to pick up about 4 in.^3.
Sorry, quick sketch and the fuel vent is upside down. :)
Chuck
AMA 76478
« Reply #8 on: March 11, 2017, 02:50:12 PM »
hi  many  buy  or make  a  7 to 8 ounce  metal tank
some  add a sump  to the  7 oz metal  tank ( 5.5 in long)
or  some run  8 oz  plastic  tank plumbed  uniflow  or  Billy  uniflow
Randyu
