The R/C person I speak of runs pipe on speed boats and I believe that's completely different, cause the way he told me to set up the pipe is way off from what I've been told here.
The correct pipe length is function of two things (that you have any control of) - the exhaust duration and the operating RPM. I am sure the boat guy is running far more RPM and the exhaust duration is not proportionally longer to compensate. And, he has no idea that your pipe also has multiple internal baffles. The multiple baffles create multiple reflections of the sound wave so there are probably 3 different potentially workable pipe lengths for any particular RPM.
For the 45FSR system you are trying to run about 11,000-11,500 in the air. That definitely does decrease the power available, since even on open exhaust, you could probably get maximum HP around 15-16,000 and probably 4-5x the power. Heck, some 15s out out over 3 hp, you are getting, and need, about .3 HP in the air. You don't want to try for 16,000 in the air, because you don't have any props that will make that work (or in other words, you have no way of dumping the grossly excess HP you would have).
