My new pipes will flow up to an 88, maybe bigger but that is the largest 2 cycle I have ran them on.
Also the pipes are tuneable by opening up either end, if the pipe seem too large and open, closing down the intake makes it act smaller..this work very well
If the pipe acts too small, opening up the venturie makes the pipe act more open. this also works very well.
Other things that can be dome to tweek the systems are to use 8, 9, 10, or 11mm size exhaust deflectors
Kaz for example uses my 75 pipe on a PA 75 with a longer smaller tube inserted into the silicone exhaust end, with a large venturie , others use the pipe as is with a smaller venturie
I think this is how the myth about outlet restrictions for the Jett started, they were having venturi issues and restricting the outlet is similar to restricting the input. But not the same, for instance, while it has a similar power effect, the fuel draw is not enhanced by restricting the outlet, if anything, it's made worse (since you are getting less flow and less velocity - if you made the venturi smaller instead, you reduce the power but it increases the fuel draw). What I think some of the Jett users missed was that there was something wrong with their venturi setup - like, it was too large for the power level they needed, they restricted the outlet, which just reduced the fuel draw and made it act even funnier. Add that to the incorrect pipe lengths that were promulgated at the time and, no chance. I think you almost always want to control the power with the venturi, not the pipe restriction, just for that reason. Once I figured out what to do with the venturi and fuel flow, then all that outlet restriction does is act, literally, like a potato in the exhaust.
A point that is sometimes missed and in our case is somewhat misleading from the "Two-Stroke Tuner's Handbook" is the relationship between the outlet and the boost from tuning. With a conventional motorcycle pipe as described, you want to make the outlet smaller because you get a larger reflecting surface. The limit is overheating due to flow restriction. But we have baffles, and if we are using them as the reflecting surface, the area of the tail cone doesn't make any difference and then a flow restriction in the outlet stinger is just a heat and power loser.
