  • June 19, 2025, 10:30:53 AM
Author Topic: Perry pump for stunt?  (Read 1427 times)
Online Gordon Tarbell
« on: October 20, 2006, 05:41:26 PM »
I have found in my old stash of stuff some new in the box perry fuel pumps to fit the St 51-56-60 , Veco 61, and St 40-46. Since some folks like to run muffler pressure on the stunt engines, I thought I might give these a go. Any of you guys ever tried these pumps before, for a stunt application?
Gordon Tarbell AMA 15019
Re: Perry pump for stunt?
« Reply #1 on: October 22, 2006, 08:35:21 AM »
OK, I guess I will be breaking new ground this winter trying this.
« Reply #2 on: October 23, 2006, 09:53:46 AM »
People have tried them and complained about the weight.  Also, the backplate style of Perry Pump has some sort of bleed hole in it that has to be postioned properly.
It's also a bunch more finicky parts to keep clean and wear out.
« Reply #3 on: October 23, 2006, 12:12:47 PM »
HI Gordon
I have used them on many differant 2 and  4 stroke engines, The results  were not  good.
They make the motors "dumb motors"  Kill off the 4-2 break. . Plus  they also have  several other  downsides.
 You may possibly  have  luck with them on 4 strokes  but  in my opinion  they are useless  for our  purposes.
Alan Hahn
« Reply #4 on: October 23, 2006, 05:33:24 PM »
That is interesting because one of the perennial debates   f~ is whether the 4-2 break is caused by the engine going lean because its nose is up and the tank head is now lower, or the increased load on the engine because the rpm drops because of the larger load going vertical (engine heat goes up). Your observations (assuming they were in-flight) supports the first view.
« Reply #5 on: October 23, 2006, 07:30:44 PM »
Thanks for the input guys. I think I might still try it ,but not with great expectations of a stellar stunt run.
