Yes, I do add Armor All to the fuel to kill off foam.
AH , But DID it kill the Foam ? .
Give it a good shake , and see if it foams .
Herein Terra Australiss , I was told a year or three ago - that " Theyve Changed It , It Doesnt Work . AND Itll form silicone in the fuel & block the spraybar "
Oh Dear . Thought this was drivle , and kept using it , off'n'on. No Worries . Untill ( Jaws Music ) The Nicely Cleaned NEW Tank , Two Weekends back I thought It ODD that
THE FUEL STILL FOAMED . Thought it even odder the stringey gunk pouring squeezebottle back into container, and the Lean Speeding Up RUNS. !
After this shambles & after a flight last weekend ( New A. All less fuel ) I pulled the filter . At the time I thought it was pva from the ex pva squeeze bottle. Though I used a syringe to Fuel It .
The Bleedy FILTER was choka ( Full if your being awkward ) With a lump of white stringey gunk . Next Flight it needled FINE .
SO , If your Out of Old Stock Armour All , and theyve ' improved it ' like here ( Aus. ) youll have to use it on your dash pad , or nylon props . it rejuvinates them . or the old one did , anyway . ( tearing hair out Icon )
Ive used all the stuff I had that worked on the dash pads & plastic .
BUGGER .
