Engine basics => Engine set up tips => Topic started by: Allan Perret on August 12, 2009, 01:10:10 PM
PA65 / pipe setup, ~10% nitro, 55~60 oz plane..
Will a 6 oz tank be big enough for the pattern ?
If I decided to go with a rear header/muffler setup instead,
does that change things relative to fuel consumption ?
Your better to put in a 7 oz tank, Yes you can restrict the motor down some and do the pattern on 6 oz with a muffler
I've got an eight ounce tank on my Berserker (muffled PA65SE with a large venturi, 0.234 in) I usually suck out a half ounce after filling and go up with 7.5 ounces of fuel. Good luck with your PA65 Allan. It's a great engine. I love all my PA's. They give me nothing but good engine runs.
Yours in Stunt,
Noel Drindak
My PA61 used 7.6-7.8 ounces depending on the temperature. That was a "hammer of Hades" sort of setup, incredible power. David's 75 setup is significantly detuned for the 75 but he used one of my old 7.8 oz tanks for a while and was just getting through, just about like my 61. Some setups take as little as 6.5 - but 6 is just not enough.
The fuel you use is pretty much proportional to the power you get - you can cut the fuel use by cutting the power. The difference in power between 6 and 7 ounces is very substantial and greatly overcomes the tiny extra weight. You can always make a tank as thick as you want, if space is a concern. Mine are all 6" long, but as much as 1 1/4" thick and 2 1/8 wide. I made one for Jim that put 8 ounces of fuel in 5 3/4". it was also tapered in 3 dimensions and almost 2" thick at the rear.
......You can always make a tank as thick as you want, if space is a concern. Mine are all 6" long, but as much as 1 1/4" thick and 2 1/8 wide. I made one for Jim that put 8 ounces of fuel in 5 3/4". it was also tapered in 3 dimensions and almost 2" thick at the rear.
Brett,
Any concern about fuel slosh away from the pickup late in the flight?
Kim Mortimore
Thats alot of fuel! Maybe you need to hang drop tanks on your Infinity to carry enough fuel for the mission! n~
