  • June 17, 2025, 02:18:08 PM
Author Topic: PA SE 51 port timing ?  (Read 811 times)
Offline Gordon Tarbell
« on: April 26, 2019, 11:06:48 AM »
Would like to know the timing specs of a PA 51 side exhaust and also the open and close timing of the inlet on the crank. Thanks.
Gordon Tarbell AMA 15019
Re: PA SE 51 port timing ?
« Reply #1 on: April 26, 2019, 03:37:15 PM »
It varies a small amount  depending on the series you have,  but  125 - 135 ex  is close, the  crank  is 185 duration that is 47 degree retarded,  The cranks on earlier ones  was  longer duration.  You can buy a cheap plastic  wheel  and  degree  yours pretty easy
« Reply #2 on: April 26, 2019, 05:49:44 PM »
 And the difference in the crank timing makes it run quite differently, not necessarily better or worse, but different. The one unequivocal difference is that the later versions are much less prone to starting backwards. Otherwise, the longer crank duration version runs more evenly through the maneuvers, which might be good or bad depending on the application.
    David's PA51 system (long crank duration version) had/has the most static thrust of any otherwise working system we have tested, much more than the PA61, PA75, or RO-Jett 61, at least in competitive trim. It's at absolutely full tilt boogie on the ground, fearsome on takeoffs because the acceleration is so high, about like an electric.
