  • July 06, 2025, 03:59:08 PM
Author Topic: Tongue Muffler pressure tap location  (Read 1002 times)
Offline Elwyn Aud
    • Inferalandings Photo Page
« on: January 27, 2008, 07:33:16 PM »
Where's the best location to put a pressure tap on a tongue muffler?
Re: Tongue Muffler pressure tap location
« Reply #1 on: January 27, 2008, 08:07:09 PM »
Elwyn; I don't know if its the best place, but I locate mine a little over half way back in either the front or back side of the muffler. Seems to work OK there. It is easy to check with the engine running, it should lean out when you pull the pressure line to the tank.
Offline don Burke
« Reply #2 on: January 28, 2008, 03:46:36 PM »
I agree, doesn't really matter a lot.  Theoretically there would be a slight increase in the static pressure at the outboard end due to wave reflection.  It would probably take a pretty sensitive meter to check the difference.  I'd just put it wherever was the most convenient for access and fit when installed.
don Burke AMA 843
Menifee, CA
