  • June 20, 2025, 12:21:17 PM
Author Topic: PA 61/pipe run issues  (Read 854 times)
Offline James Mills
« on: June 29, 2010, 09:49:40 PM »
Randy,
I've hit some problems with my PA 61/pipe set up on my Tempest (same set up I spoke with you about).  I went out this afternoon and couldn't get a needle setting.  First flight was a bit fast, opened the needle on the second and was slow and so on.  A couple of time when I tried to set the needle I opened it 1-1.5 turns with no change then it would start to sound like a sick Harley.  I tried several props, all 12 3-blade, pitched at 4, 4.2, 2.3.  I'm wondering if I may have toasted the pipe (there was a horrible smell coming from even after I got home, not sure how to describe it).
James
AMA 491167
Online RandySmith
Re: PA 61/pipe run issues
« Reply #1 on: June 29, 2010, 11:10:58 PM »
Randy,
James
Hi James
It sounds like the NVA has been removed and installed improperl;y with the holes NOT lining up. OR the fuel feed has a blockage, or trash. It also sounds like you may have fried the pipe ...if the motor ran so lean to cook the pipe and make a very bad smell, It needs to be checked.
The only way to do that is for me to see the power train in person
Offline James Mills
« Reply #2 on: July 06, 2010, 10:55:02 PM »
Randy,
Thanks for the help.  I thoroughly cleaned the NV assembly and the run seems to be back.  See you at the Nats.
James
AMA 491167
