  • June 24, 2025, 10:22:12 PM
Author Topic: "Going off the reservation"!  (Read 812 times)
« on: January 03, 2011, 10:38:40 AM »
Well it had to happen sooner or later..... I am going to "possibly" have to change the set up in my new stunter once it is flown.  The engine is a PA .51RE and I am going to be using a slip on "can" muffler, instead of a pipe.  (due to fuselage "bottom" construction restraints)
Just got off the phone with Randy (who else to talk to about "his" engines? LOL!!) and he told me I "might" have to change the venturi once test flights start.  That will be a totally new experience for me.  IN the past, I just ran what was put in the engine and have nver had to really worry about changing it.  Looks like I am about to be drug, kicking and screaming, into the darkness! LOL!! I will actually have to think of the possibility of changing a venturi........ and things were going so easily!
LL~ LL~
Big bear
Offline Balsa Butcher
  • High Desert Flier
Re: "Going off the reservation"!
« Reply #1 on: January 03, 2011, 04:04:20 PM »
Nothing to it Bill, you'll do fine.  n~
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #2 on: January 03, 2011, 06:25:20 PM »
Yeah, guys, once I get over the shock, I will probably be OK.
maybe........
 :##  n~  LL~ LL~
