  • June 21, 2025, 03:58:41 PM
Author Topic: old os max .35  (Read 1386 times)
Online John KruziK
old os max .35
« on: April 01, 2007, 03:32:49 PM »
Should I use the same fuel in an old 70's os max .35 as a fox .35? Thanks John
AMA 874027
Offline Ralph Wenzel (d)
Re: old os max .35
« Reply #1 on: April 01, 2007, 06:01:43 PM »
Yes.
Ralph Wenzel
AMA 495785 League City, TX
Re: old os max .35
« Reply #2 on: April 01, 2007, 09:49:07 PM »
At least 25% all castor, if that's what you're already using in the Fox 35.
Offline Ken Deboy
    • Silk and Dope
Re: old os max .35
« Reply #3 on: April 01, 2007, 10:09:31 PM »
I use 29% castor fuel in my Max 35-S and it runs fine. At first I had problems getting it to run through a full tank but switching to an RC style pluf (Fox RC Long) turned it into a nice reliable engine.
cheers,
There is a fine line between "hobby" and "mental illness"
Re: old os max .35
« Reply #4 on: April 02, 2007, 12:46:42 PM »
http://stunthanger.com/smf/index.php?topic=4037.0
Hi John
Depends on if it is new or used  , and  what fuel it has been run on. I  would suggest reading this
I have FOX 35s  and  OS 35S  engines that are mine personally  ran on 25% synth/castor blend  and  are still very good engines that have a very small amount of wear, many 100s of flights ,and  are NOT  burned black with baked-on castor.
Offline Manuel Cortes
Re: old os max .35
« Reply #5 on: April 03, 2007, 05:50:41 AM »
Hello all.
Randy, are you refering to lapped pistons or ABC aftermarket units?
Thanks in advance.
Manuel.
Re: old os max .35
« Reply #6 on: April 03, 2007, 12:58:42 PM »
Hello all.
Thanks in advance.
Manuel.
Hello
I am refering to the stock  Lapped  iron steel  setup
Do you have  an aftermarket ABC in this engine?
