  • June 23, 2025, 04:22:59 AM
Author Topic: PA 40 UL Prop choices?  (Read 948 times)
« on: September 22, 2011, 10:06:13 AM »
What are some good inexpensive props that can be used on this type of engine?
Re: PA 40 UL Prop choices?
« Reply #1 on: September 22, 2011, 02:34:23 PM »
Randy Powell has the only one in the NW that has been flying it (Shoestring & Cobra). Usually uses the TT Cyclone 11 x 4.5 ($2 from Tower in the 6 pack!), but that is using his own header muffler. I'm planning on running a pipe on mine, and will probably start with the TT prop.  H^^ Steve
