Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 24, 2025, 03:15:10 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
Overpowering an airplane
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Overpowering an airplane (Read 788 times)
James Mills
AMA Member and supporter
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
on:
August 28, 2009, 08:23:14 PM »
After seeing the post by Brett of the gentlemans plane with the 65 pipe set up under 600 squares I am curious how to know if you have too much power/engine?
James
Logged
AMA 491167
dennis lipsett
Trade Count:
0
Admiral
Re: Overpowering an airplane
Reply #1 on:
August 28, 2009, 08:33:33 PM »
When your shoulder is always sore, you can't hold a cup of coffee comfortably, and your flying arm is 2 inches longer then the other then you have a problem of too much power.
Logged
jim gilmore
Trade Count:
0
Admiral
Reply #2 on:
August 29, 2009, 06:42:12 AM »
I don't believe that too much power is a possibility in unthrottled airplane. The model that has too much power will be going way too fast. So one basically depitch's the prop to reduce the power.
The question is how to keep enough load on the engine. Bigger prop more blades or wider blades ?
Logged
Gary Anderson
Trade Count:
0
Captain
Reply #3 on:
August 29, 2009, 10:55:06 AM »
Hi guys,
I guess if the prop is bigger than the wings you could have a problem
Logged
Gary Anderson
jim gilmore
Trade Count:
0
Admiral
Reply #4 on:
August 29, 2009, 01:42:46 PM »
Heck, if the prop is bigger than the l/g is long you got a problem.
but if the engine fits/and the plane can balance/and the all up weight will allow it to fly the pattern, then size isn't too big.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
