I see a pressure tap on the remains of the muffler, but can't see a hose going to the muffler in the first picture of the engine installation. However, if it did have muffler pressure, as the muffler fracture got bigger, the engine leaned out. As much as I like muffler pressure on some engines, you've GOT to make sure stuff isn't going to come loose or otherwise fail, causing a reduction in muffler pressure. Engine goes lean and the engine won't survive too much of that mistreatment.
Matt, you'd help us a lot if you'd just post jpegs instead of all these pdf files. We could more easily refer to multiple pictures, etc.
Another thing...have you been using a pitch gauge, or are you going off the nominal pitches of the props you use? The MA props are VERY much below nominal, while the APC's at least act like they're a bit higher than the label. Different animals, for sure.
I'd like to see you get a pitch gauge, and would like to see you stick to either APC or XOAR for awhile, because they're consistent and most seem to work pretty good for stunt, if you're anywhere close to correct in size and pitch. Not everybody is ready for CF props; that's just the way it is. If you don't get a pitch gauge and use it, CF props generally won't work very well. Price of doing business, I guess. Get one or make one. Howard appears to check his prop pitch with his cell phone...I haven't really paid much attention to that, because I'm sure my flip-phone wouldn't do it. But it does fit in my pocket better, and it makes calls just as well.
