  • July 06, 2025, 12:00:46 AM
Author Topic: OSLA 25  (Read 5913 times)
Offline Bob Disharoon
OSLA 25
« on: June 14, 2007, 05:40:39 AM »
JUst bought one and put it on an ARF flight streak....could never get the thing to run more than 10 secs. Right fuel, prop,etc. Changed tanks, plug, plumbing...everything I could think of..6 hrs. worth!....anyway, its on its way back to Tower Hobby. Has anyone had any similair problems, I need some sympathy..waaaaaaahhh
Re: OSLA 25
« Reply #1 on: June 14, 2007, 07:13:07 AM »
never saw one that wouldn't run.  If it runs 10 sec there probably aren't any problems with the motor.  OS has produced several different size venturis that will fit, some with a pretty large ID.  With the OS fuel nozzle supplied(same diameter as an OS needle valve) the venturi ID should be .25 to .26 or so.  They did produce some venturis as large as .281, which probably won't draw fuel well on the 25.
 Are you using the stock remote needlevalve?  If so, the fact that the fuel has to travel up to the needle and back down will cause some problems on starting.  Usually all the fuel drains back into the tank.  Even with a heavy prime the engine will often only run a few seconds on the prime and then die just as the fuel is starting to get sucked up  to the venturi.  The trick is to have your thumb poised over the carb and when the engines fires and starts to run briefly choke it to pull the fuel up to the carb.  The simplest fix is to bypass the remote needle and put the standard OS needle valve through the case, in the usual position.
Offline don Burke
Re: OSLA 25
« Reply #2 on: June 14, 2007, 08:31:13 AM »
The 25s will draw fuel well enough for racing with a .315 venturi. Sounds like an air leak.
don Burke AMA 843
Menifee, CA
Re: OSLA 25
« Reply #3 on: June 14, 2007, 09:31:14 AM »
remote needle..the only thing not checked was backplate seal..like I mentioned, its on its way back to the OS hospital
Offline Steve Holt
Re: OSLA 25
« Reply #4 on: June 14, 2007, 10:14:12 AM »
Bob,
When my LA25 was new, it would do the same thing.  To get it running, I had to open the needle valve a lot, 8 or 9 turns as I remember.  Once running, it ran OK.  For restarts, I had to open the needle valve about a 1/2 turn to get it started then reset to running position.  I replaced the backplate with a metal backplate and installed a conventional needle valve.  It now runs great and operates normally.  My guess is that this particular rear needle valve had an air leak.  I had been planning to replace the plastic back plate anyway so I was lucky enough to have the repacement parts on hand.
Re: OSLA 25
« Reply #5 on: June 14, 2007, 08:57:34 PM »
As I've posted before... S?P...one of our club members had two .15LA's on a twin, and one would quit after 2 or 3 laps, every time. The fact that it was always the inboard engine made it a bit exciting. Replacing the backplates with TT GP .15 units solved the problem. So, yes, it's an air leak! It's a lot less exciting, and a better use of your time at the field, to do this stuff before you put the engine in the plane, OBTW.  D>K Steve
Re: OSLA 25
« Reply #6 on: June 15, 2007, 04:41:12 AM »
just as easy to mount it with the tank on the fuse as it would be to setup a bench mount...test ran the whole thing a on foldable field bench in the driveway..which reminds me: Home depot, etc. sell a 2x2 foldable heavy plastic worktable with various holes molded in. Just glue 2 pieces of wood in the back holes. to butt the tailfeathers and youve got a really handy item..it stands appxox 3 ft high and folds flat.
Re: OSLA 25
« Reply #7 on: June 15, 2007, 04:43:04 AM »
one more question ..can someone post the link for the conventional NVA for the OS 25?...I dont want to buy the wrong one..thanks!..Bob
Offline don Burke
Re: OSLA 25
« Reply #8 on: June 15, 2007, 10:19:45 AM »
Here's what I just found.  Found it by searching Tower for OS Needle Valves Assy.  I think the  NVA is used on all up to 46.
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXCR49&P=ML
don Burke AMA 843
Menifee, CA
Offline Ken Deboy
    • Silk and Dope
Re: OSLA 25
« Reply #9 on: June 15, 2007, 06:45:19 PM »
I've put this NVA in 2 LA 25's and an LA 46 and it fits both, works fine. Also, the FP Cover Plate they sell for the FP 20 will replace the plastic back cover the LA 25 comes with.
cheers,
There is a fine line between "hobby" and "mental illness"
Re: OSLA 25
« Reply #10 on: June 16, 2007, 05:18:46 AM »
thanx for the info..do you need a different venturi for the new NVA?
Offline Ken Deboy
    • Silk and Dope
Re: OSLA 25
« Reply #11 on: June 16, 2007, 08:43:41 AM »
No
cheers,
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #12 on: June 16, 2007, 01:02:41 PM »
You might want to check out (search for) Mike Pratt's post on Stuka Stunt.
How he made OS.25LA run right. It work great for me.
Stopped me from turning my .25 LA into a fishing weight.
Jerry Bohn
Re: OSLA 25
« Reply #13 on: June 16, 2007, 03:41:50 PM »
Jerry..thanx for the tip..but could not find anything on Stuka at all..they only go back 30 days for a search..maybe thats the problem. Do you possibly remember any of the strong points of his thread that really impacted running the engine better?..thanx again, Bob
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #14 on: June 17, 2007, 05:25:38 AM »
Bob. I was just looking at the old post a few days ago. I'll see if I can find it again, it's hard to do on Stuka, I believe it was about a year ago. I think you can check way back then. I''ll let ya know.
Main fix for good run was new .250 venturi,ST needle valve, stock muffler on uniflow no pressure, metal backplate. I myself, went with a .255 venturi.
Mike used it on first prototype Pimary force at contest in Denver, I talked personally with him about his 25LA set up.
I'll re-search Stuka again so you get all the right stuff.
Jerry
Jerry Bohn
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #15 on: June 17, 2007, 05:55:51 AM »
Bob, Check Stuka again
Post titled "OS .25LA & FP" (I searched Subject only, "OS.25 LA", All Dates.)
Sept.29, 2002
By Mikey
I saved it, could send it from Stuka if ya cant find it, if your e-mail is listed.
Let me know if ya can or can not find it, it is there.
All mods and tips are there. His as mine did run great after changes. Got mine in a Barnstormer. I use a 9x4 Zinger, 9x5 on windy days.
15% Nitro, 24% oil 50/50. The 15 %Nitro is for my 5000' altitude.
Breakin time may vary, I did 2 min heat cycle. Two-4oz. tankfuls.
Jerry Bohn
« Last Edit: June 17, 2007, 02:51:35 PM by Jerry Bohn »
Jerry Bohn
Re: OSLA 25
« Reply #16 on: June 17, 2007, 02:51:28 PM »
Thanks, Jerry..I still cant locate it on Stuka..sorry Anyway, if you could send it along to mole21401@yahoo.com., that would be great!..Bob
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #17 on: June 17, 2007, 02:58:06 PM »
Bob, Hows that for service hope it helps.
"OS .25 LA & FP Setup"
           After receiving a number of phone call and e-mails about how I was setting up the OS .25 FP & LA for the Primary Force I thought it would be a good idea to post it here. Please don’t think I know all there is to no about these engines but I have found a few things that worked really well.
OS .25LA: I used the engine in stock form and was quite surprised how well it ran right out of the box after a short break-in. There were a few things about the engine I didn’t like but the biggest thing was its lack of consistency (I am really fussy when it comes to engine runs but I believe that most sport flyers would be more than happy with the way the engine runs out of the box). I had to reset the needle before every flight and it was almost impossible get the same setting flight after flight. During some flights it would drop out of the rich 2-cycle and into a doggie 4-cycle for a few laps and then jump back to rich 2-cycle. In addition, the engine would go lean and almost quit in the second loop of the four-leaf clover (with plenty of fuel still in the tank).
I thought the rear mounted remote needle was the culprit and replaced the remote needle with a ST needle valve assembly (through the venturi). This was a little better but still far from what I wanted. I used different combinations of fuels, glow plugs, head shims, air filters, and muffler pressure with little or no change to the run. Completely frustrated, I switched to a tongue muffler and instantly most of the problems went away. The run was much smoother and more consistent cruising along at a rich 2-cycle but it still had a tendency to lean out in the four-leaf. Using a Bru-Line green air filter helped and almost stopped the leaning out at the end of the flight, but switching to a .250 dia. venturi (from Leonard at SSW) cured the problem completely. One other little change that I made was making a plug for the uni-flow vent that had a .050 hole drilled in the end to keep the engine from running a little fat (rich) at the end of the pattern.
Now the little .25 LA runs like a Singer sewing machine from the beginning to the end of the tank with a short power burst one lap before it runs out of fuel.
Listed below are the suggested changes and/or parts needed:
.250” i.d. Venturi.
S. T. needle valve assembly.
Tongue Muffler. Modified RSM or SSW
3 ounce Uni-flow tank (1” x 2” x 3”) Brodak or GRW.
Props: APC 9” x 4”& *10” x 4” (*trimmed to 9-1/2”).
Grisch 9” x 4” Black Magnum
Bolly 9-1/2” x 4-1/2” (re-pitched to 4”).
Glow Plug: S-300 Sonictronics or Thunderbolt R/C.
Fuel: Sig Champion 10 or 15% ½ synthetic & ½ castor.
RPM: Set at 10,2 to 10,500 on the ground depending on your prop choice. It should be braking back and forth from a 2-cycle to a 4-cycle (more 2 than 4) and as it warms up it should be in a rich 2-cycle (by the time you reach the handle). After launch, the model should speed up during the first lap and as the engine cools a little you should hear it back off a little into a rich 2-cycle.
OS .25 FP: This was really easy to setup because the above modifications worked perfectly on the FP. There was no need to plug the boost port or angle the intake ports on the FP. It ran really sweet and I think it even has a little more power than the LA. The FP liked the Bolly 9-1/2” x 4-1/2” with the pitch set at 3.75”.
One other thing that I will point out is I live at an altitude of 5000’ so some of the changes and settings maybe a little different at lower elevations. When I travel to contests (at lower elevations) about the only changes I make to the engine is adding a Bru-Line green air filter and if it is really hot I switch to 15% nitro fuel.
« Last Edit: June 17, 2007, 05:20:17 PM by Jerry Bohn »
Jerry Bohn
Re: OSLA 25
« Reply #18 on: June 18, 2007, 05:17:32 AM »
Jerry!..you are the man....thanx a ton..Bob
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #19 on: June 18, 2007, 05:55:13 AM »
Bob, Your welcome. Glad I could help. I'm not the greatest flyer, I've received a lot of help from others on the forums in the past 12 years, glad I could contribute for someone else.
By the way, I use the stock OS muffler, runs good for me.
Jerry
Jerry Bohn
Re: OSLA 25
« Reply #20 on: June 18, 2007, 03:23:41 PM »
Jerry..one more question and I promise to leave you alone!...are you running on pressure or not?
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #21 on: June 18, 2007, 08:21:12 PM »
No pressue, no restritor on uniflow line intake, never had any problem with end of runs. Tried restictor, made no difference that I could tell. Mikey may be a bit more particular than I am.
Feel free to ask as much as you like. Engine gurues answered all mine till I was very happily satified. They were concerened that I really understood what they were telling me. So I will help anyone who asks a question, no BS, if I don't know it from experience, I'll say so.
I think it's hard to troubleshoot engine problems on the forum for others, with my limited knowledge. Same engines run different for different people. Must have to do with fuel, props altitude, plane used on and luck.  My hats off to others who did it for me.
My main concern is you got Mike Pratts info first hand and I verify it made a world of difference for my OS25LA.
Good luck with engine, Feel free to ask away.
Now to get my 40LA to run as good as my .25LA and .46LA, seems like there different animals. But, I'll get it sooner or later. Thats part of the fun unless thats the only engine ya got and ya want to fly soon.
Jerry
Jerry Bohn
Re: OSLA 25
« Reply #22 on: June 19, 2007, 05:20:46 AM »
I ordered the metal backplate and NVA, but have to wait till the motor comes back..however Ive got some other good running stuff, so no withdrawal problems!
   Bob
Re: OSLA 25
« Reply #23 on: July 02, 2007, 05:03:28 PM »
I just received My OSLA25 from Tower hobbies for repair...it was new and did not run worth a C%^p. Anyway, if anyone  wants to know the outcome, they replaced almost EVERYTHING but the crankcase.Maybe it was a total dud, or they do this for good measure on all returns. I will be trying it out tomorrow, and we will see.
Offline Jerry Bohn
  • ACE
Re: OSLA 25
« Reply #24 on: July 02, 2007, 07:00:57 PM »
Bob, It sould run fine on a test stand. The good stunt run comes after the modifications and breakin. It may surprise you on the bench, even 4-2-4. It's in the air on a plane where most of the problems (erratic) show up. Hope your putting it on the bench for heat cycle break in. A lot of guys say just run a tankful of fuel and fly it. I say bullpuckey. The more you run the new LAs the better they get till there totally broke in. Your breakin mileage may vary.
Best of luck after having run into possibly a lemon.
Jerry Bohn
Re: OSLA 25
« Reply #25 on: July 02, 2007, 07:02:39 PM »
My guess is that they trouble shoot an engine like a typical home car mechanic (not technician) did 30 years ago. "It needs a tuneup." "And spark plug wires, rotor, and cap." Still won't run right. "And coil." "The ignition switch must be bad."  Hey, that reminds me...did you ask for all the old parts? You should be able to get them back, buy a crankcase, and put together another engine. Or maybe that's what the dude at Tower did...after throwing 'em into his lunch box.
Remember the 3 rules: Fuel, spark, and compression. If you have all 3, your engine will run, unless you put the sleeve in backwards, or the backplate leaks. The cylinder is pinned on those OS's (fine idea!), so I'd bet a dollar that the backplate leaked, or you didn't have those 3 requirements working for you. That would include a blocked spraybar, spraybar not pointed the right direction, duff glowplug, or maybe a honey bee down the venturi.  :X Steve
Re: OSLA 25
« Reply #26 on: July 03, 2007, 05:15:13 AM »
I guess I'll never know the real reason. I'm planning on breaking it in in stock mode, then switch to alternate NVA and metal backplate if flights are not up to snuff.
Re: OSLA 25
« Reply #27 on: July 30, 2007, 04:29:02 PM »
Sorry for the long delay posting re: la25....got it back TOTALLY rebuilt..installed the alum backplate and conventional NVA and bench ran a break in.....Now, this thing is super!..put it on a Flight Streak and that combo is VERY fast....at least for 60 yr. old me. I would reccommend taking all the the plastic off the engine and go with what I did...thanx, Bob
Re: OSLA 25
« Reply #28 on: July 30, 2007, 11:14:11 PM »
Hi Bob,
It's really a "no brainer" for me to replace the plastic backplates on the LA engines.  That part is a very likely trouble spot, and putting on an aluminum backplate is worth it, up front, to not have that part to worry about when at the field.
As to the remote NVAs, I have never used one, and probably never will.  Just an "old timer" I guess, but I like to take every possible sore spot out of the equation beforehand. ;D
Offline Les Akre
Re: OSLA 25
« Reply #29 on: July 31, 2007, 04:23:40 PM »
Hi Bob
On my LA's the plastic backplate per se was never the problem, only the poor excuse for a remote needle setup had me fuming. The fuel pickup nipple on the remote needle assembly (from tank to needle assembly) is positioned entirely incorrect for anything save some unusual R/C setup. It should point straight back at the very least, not sideways! Also, some of them leak!
Anyway, I removed the offending appendage on all of my LA's and just run the regular front needle setup. I'll try and include a pic of my modified backplate sans the remote assembly.
Best regards, Les
