  • July 05, 2025, 07:36:04 PM
Author Topic: OS25FP needle valve  (Read 810 times)
Offline James Mills
OS25FP needle valve
« on: August 18, 2010, 09:57:38 PM »
Is there another needle valve assembly that works well for the FP 25 if you don't have an orgional?
James
AMA 491167
Offline Bootlegger
Re: OS25FP needle valve
« Reply #1 on: August 19, 2010, 05:12:38 AM »
  Try a Super Tiger, they work well. Seems that the 51 is the one that I use, but check, and you will have to drill the venturi and case to about .166 as the tiger needle is somewhat larger..
     Good luck :!
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #2 on: August 19, 2010, 03:41:07 PM »
James
  The ST or PA works if you drill out the hole, and then make the venturi larger. But you can still get the originals from Tower.
Online Geoff Goodworth
« Reply #3 on: August 20, 2010, 07:01:24 PM »
To save you some work, the Tower catalogue number for the OS NVA is LXCR49.
