Engine basics => Engine set up tips => Topic started by: Fredvon4 on July 22, 2016, 12:10:39 PM
I have been in search for a few OS FP 20 ABN and have received a older FP 20 with the large bypass ports obvious on the outside (iron liner version?)
This one had a RC carb and the 842 muffler
I installed the BBTU recommended OS Venturi, NVA and 2030 muffler
While doing this, I discovered a very small threaded hole right below the exhaust side mounting lug into the crank case...2/56 bolt will NOT thread in properly but it is a close fit..I just assume some other thread pitch...I also assumed it was for CC pressure but in a very odd location
I asked the seller if he had the pressure nipple or knew the thread size....his response was the engine runs great and he was not aware of the CC hole
very curious to me and I figured I was now in search of a good CC for it
I mounted it up today, primed with 15% N 22% oil 50/50....just to see if the seller was full of hooey
It fires easy, needles just fine and runs a steady 8800 RPM rich up to 12,400 lean with a MS 9x4 S2 Series thin blade prop......NOTE: MY last APC 9x4 is not balanced yet
Why the hell will this 2 stroke engine even start and run with a vent to atmosphere in the Crank case...???
One note...as I rotate the shaft I can see shiny (Crank shaft counter ballance I assume) pass by the small hole in the case
I may just clean the area real good, lightly sand, perfectly de-grease, and smear a skim of J&B weld to close the hole
Thought, opinions
Allot of engines will still run with a pressure tap hole open to the outside but, it should be plugged. JB weld should work well if completely degreased.
MM
I'm going to guess that if M2.5x0.5 is a standard metric size, that's what it is.
If you plug it with JB weld and it falls out, try plugging it again with a very short 2-56 screw dipped in JB weld.
OK thanks for the reply's
Same sort of subject
I have a few new ringmasters and a soon to be built SkyRay as well as another Larger Ringmaster from Pat Johnston...the 526 RM will get one of my new in box Evo .36
I have been somewhat impressed buy the Bret Buck recommendation of the OS 20 and associated BBTU commentary and my personal experience is this system works a tad bit better than the Old skool Fox 35
That all said, I am a casual flyer...no contest aspirations. I just want to find myself at the field with a power system that does not demand a lot of fussing around
The Fox 35 (no burp plug) on one (Mike Griffin ARF RM) is prefect for my pseudo stunt flying
I built a RST with RM tail and it is powered by a blue La 25 and near perfect for me also
I have bought two FP20s but they are the large hump so called "iron liner" versions and run fine on the bench
I recently won a FP 20 no hump, assumed ABN version and it too starts and runs fine on the bench
I am using the OS Venturi and NVA assy as well as the 2030 muffler fed with home brew 15% N...22%oil half half and each starts and needles with a fairly broad NVA range from 8000+/-Rpm up to 10,700~12,200 rpm using a typical 9x4 prop
OK now the question....
I thought the ABN version was the preferable one until I read recently that the Iron liner one was stronger....in this thread
http://stunthanger.com/smf/open-forum/ringmaster-with-a-os-25/?topicseen
where Phil Spillman claimed the Iron version was preferred.......so I am confused
Am I concentrating on finding the wrong OS FP engines
I thought the ABN version was the preferable one until I read recently that the Iron liner one was stronger....in this thread http://stunthanger.com/smf/open-forum/ringmaster-with-a-os-25/?topicseen where Phil Spillman claimed the Iron version was preferred.......so I am confused. Am I concentrating on finding the wrong OS FP engines?
Fred, opinions abound. I've been told I should can my Testors McCoy .35 Red Heads, they won't last, that I should get a reliable OS Max .25LA and be done with it, that I'd be more happy. I heard there were some issues with some batches of the ABNs shedding their nickel plating. Others have success with the OS Max .20FP ABN. I think the steel lined one is favored because of its very long wearing qualities.
If I were you I'd PM folks like Bill Little, Pat Johnston, Dennis Lipsett, etc. John (Doc) Holliday may be able to help, too. They are straight shooters and should advise you right. They have helped me out a lot.
"It fires easy, needles just fine and runs a steady 8800 RPM rich up to 12,400 lean with a MS 9x4 S2 Series thin blade prop......NOTE: MY last APC 9x4 is not balanced yet
Fred, with all due respect but out of curiosity .... why are you gonna' mess with it .... especially since you said it runs so nice?? To me, it seems like you might be preparing to kill the Golden Goose!
the 40 FP iron piston ( hump case) is much less prone to having run away problems, I have not heard of that being an issue with either version of the 20 FP
Jim sorry I did not see your question until today
I am still curious why it runs so well with the hole in the CC
a few times in the past an erratic engine run was tracked down to a air leak at the Back plate and once a crack in the crank case from one too many vertical arrivals
While running it does NOT spew fuel OUT of the CC hole. I wonder if there may be something similar to sub piston clean air induction happening due to the timing of the crank shaft counter balance passing this very small and oddly placed hole
I think I will cover it temporarily with a small piece of gorilla tape and see if there is any run difference that I can detect
If no difference I will JB close the hole just to keep dust n grass seeds out of the Crank case
If there is a noticeable difference with the hole temporarily plugged I will be even MORE curious
I think you've answered all your own questions, Fred. The motor seems to run fine. The hole is small so any leak is small and repeatable, unlike a leaky backplate which bounces around. Of you can see the counterweight go by the piston is on the upstroke and the counterweight probably acts like a leaky valve, partially block flow through the whole when it needs to be blocked. But it would be a good idea to plug it permanently with one of the suggested ways, unless you want to run crankcase pressure to the tank.
Thanks Phil
I have a hard time understanding why the Tapped (I looked with a 9x Loup) is directly under and centered below the exhaust side mounting lug. For profile mounting I can not think of an easy way to use it as a pressure tap....the other curious about this TAPPED hole is how thin the CC is right there and how close the crank shaft is to the inner wall... any screw or tap would only have 1.5 threads engaged and not be a very strong fit
Bottom line is thanks to all who responded I think I will just close the hole and go flying....
I do plan on using the 2030 muffler ---with or without Muffler pressure depending on run with my clunk tank options
I would like to hear your results, when you get them. I'm kind of expecting that with the hole plugged it'll be easier to start and that it'll run ever so slightly slower but (if you took the trouble to do A-B comparisons) more reliably. But I could be wrong.
Tim...because the weather is 100+ every day now for last 2 weeks--- I may just bolt it up, get a run or two noting ease of start, Needle range, rpm with typical 9x4 prop
Then Cover the hole and repeat--- noting any differences with same fuel and prop on the bench
I am sort of thinking there may be some little sub piston type fresh air charge being introduced so maybe there will be a noticeable difference...at this point just a curiosity
The original owner claims it was NIB when he put it into service and never knew there was a hole and it (in a RC application) started and ran fine when he used it
The engine came to me in the OS box and was clean on the outside and piston looks nice and un-scored with light brown piston top (seen in the plug hole)
While I was removing the carb and installing the venturi/NVA is when I noticed the hole
I refuse to believe OS shipped it with this hole...if posting a photo was not such a pain on this site...but i digress
BTW the included 842 muffler was never put into service and I recently sent it to a Flying Lines want ad..you know him
I got it for a good price, it runs well, but I have a hard time believing the hole was not noticed....BUT--- it just may be as simple as he is older like me and thinking of a different engine...he sold about 5 engines at the time I bid on this one
Thanks Phil
I agree, just plug it up and move on. I can't see any good reason to have a hole there, even if you wanted to tap it for pressure. Based on Howard and Pauls experimentation with the 15FP, it is far from clear that using crankcase pressure on the FPs even works in a stable manner. In some cases the crankcase pressure went down with increasing RPM with pretty much guarantees on unstable system, unless you do something else, too.
Even with the exhaust tuning, I think (actually, I am sure) the pressure in the muffler is positive all the time, even if the node of the wave happens to lie near the tap. If you do not run muffler pressure, make sure the tank is no wider than about 1.5" so you will be sure to have enough delivery pressure throughout.
p.s. I am sure the hole was not there when it left the factory for all the reasons you state, moreover, I am certain that there is an almost entirely automated machining process that would not include a drilling and tapping random holes in the crankcase operation! There may indeed be some sub-piston induction going on but its negligble through such a small hole. Some engines had holes left intentionall in various places to get some sub-piston induction (Anderson Spitfire for example) but those are almost always up near the exhaust so that they are closed off for most of the stroke, which is what you need.
Again...a big tanks to all following this way out of production and curious engine I got for $40
No matter where I go on this and a few other sites I continually learn and have started to really enjoy this hobby quite a bit more than my frustrating efforts of my youth
I have not yet ever had a engine explode...crank shaft break, or even a shaft run....but when it eventually happens ...I will know what caused it and probably laugh my ass off. Just as I do when I make a PERFECT figure nine early landing with no flair to final...you know the vertical landing and passenger -immediate- disembark operation!....grin
all you guys are making my late fifties early sixties real fun...again thanks to all who respond and offer your wise and sage advice
