  • August 05, 2025, 07:38:44 AM
Author Topic: Old Fox Stunt engines?  (Read 6676 times)
Offline frank mccune
« on: October 02, 2017, 07:49:46 AM »
         Hi All:
         I was flying a CG Shoestring for the first time the other day and I noticed vibration being transferred to the handle via the lines. I was using my "best" Fox 35 Stunt.  I changed engines to my no. 2 Fox 35 Stunt and had the same problem.  Yes, the props are balanced and the crankshafts are straight and all fasteners are tight.
       A flying mate suggested that I am wasting my time with the Fox 35 Stunt as this is the way they perform.  I do not have any vibration problems with other engines.  I have the same problem with a old Nobler and a Fox 35 Stunt.  This leads me to ask the question if old Fox 35 Stunts would vibrate less and not have the burp.  What year did the Fox 35 develop the burp?
     I have the following in my "Junk Drawer: Fox 35 1949, Fox 35 1951, Fox 35 and 29 1953 engines.  Would I gain anything by switching to these older Fox engines?  Are they smoother running and do they have the Fox Burp?  These engines are like new and have tremendous amount of compression.  I have heard that the Fox 29 Stunt was much smoother running than the 35 due to its lighter reciprocating parts.  May be an urban myth.
     Should I give up on these engines and use McCoy, Enya, OS and ST engines?  These engines seem to work very well in all applications.  If the answer is yes, I can see many enjoyable hours spent changing engines. Lol
     One of the smoothest planes that I fly is the Sterling F 51 powered by a cheap McCoy 35.  The engine starts first flip, has adequate power and is very smooth running.  It is a joy to fly.
     Is it time to make the change?
        Tia,
        Frank McCune
Re: Old Fox Stunt engines?
« Reply #1 on: October 02, 2017, 10:27:36 AM »
   For God's sake, YES, it was time to change 40 years ago. And it hasn't been a mainstream competitive stunt engine for about *50* years. It was never a very good sport flying engine compared to many far easier-to-deal with alternatives.
   People used it for sport flying because it was a pretty good competition engine for a brief period in the 50's and then (just like now, to a degree) people wanted to be able to brag about it even if it didn't make any difference for what they were trying to do. It's the same phenomenon that drives every sport flier and casual competitor into buying a "Joe Blow 40LA" instead of a stocker - it has nothing to do with the performance (which is usually much worse than stock), it has to do with wanting to tell their pals they have a "Joe Blow 40LA".   This is the result of a second problem, where many competition aspirants can't grasp a similar situation, where ST46/60s and the like ALSO aren't mainstream competitive stunt engines, not for about *30* years.
    At this point, we have people out there in the field torturing themselves for hours trying to get it to work, burp-quit-crash or shaking the airplane to bits in 3 flights, and then claiming how great the engine is.
   These endless problems were potentially worth putting up with because when you got it working right, it was the best you could do in the mid-50's, and about even compared to most of your competitors through most of the 60s unless you were going to take on McFarland/Gialdini etc. Geiseke managed to hold on through most of the 70's but it eventually became too much even for him to overcome. A lot of the alternatives were not tremendously better in terms of performance but you don't have to be a lot better, just a little.
And don't move on to "McCoy/Enya/ST" because they are hardly any better for the most part. Enya now occasionally makes a modern-quality products on a very limited basis, ST makes more-or-less nothing too useful, and McCoy has been out of business far longer than Fox. OS is still in business but doesn't make CL engines, and if you convert a OS-35AX to CL, it has 5x the power you need to fly a Shoestring. Get a few year old 25LA or 20/25FP, convert it to CL with factory parts.
   Note also that the same problem infests budding stunt competitors, still trying to hold on to the 80's to avoid anything "complicated" like a 40VF - which is ironically the EASIEST of all the recent generation to deal with. You bolt it together and go fly it, you need to know very little compared to the old days, it just goes and goes.
      Expect my two cyber-stalkers to descend upon this thread to "correct" me and to claim they have advanced knowledge and that I am un-American, but I am trying to break you into the reality of the year 2017 instead of desperately hang on to 1956. Get a used 25LA from an RC guy, put in a stock venturi and a APC 9-4, and move on with your life.
« Reply #2 on: October 02, 2017, 11:46:20 AM »
       Hi Brett:
       I was hoping somebody would knock some sense into my head!  Why do I insist using this ole technology after seeing how well the more modern engines perform.
      I do have an OS .40 LA that I have only used as a Diesel and a Brodak .25 that are modern.  I will test the Brodak to determine if it will pull a Sterling Mustang, YAK 9 and the CG profiles.  If not, hello to something more modern.
     One last engine to consider for a sport engine.  I have an old OS .35 circa 1956 that may be a great engine.  I feel like the person on the  TV series Horders who is saying goodbye to his "valuable" things. Lol
      Again Brett, thanks for being a person of reason!
        Be well,
        Frank McCune
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: October 02, 2017, 12:40:22 PM »
In reference to shaking the lines : it shouldn't vibrate that much. Maybe check the con-rod and crank pin fit?
As far as upgrading, I don't know. I like them on a bi-slob. They sound cool!
Offline philip metzner
  • chevyiron420
« Reply #4 on: October 16, 2017, 01:07:31 AM »
         Hi All:
     Your experience mirrors mine. Some fox 35's will shake so violently they will bust the wing root loose from the fuse. Mine did on a very solidly built s1a ringmaster. Install two head gaskets, thunderbolt rc long plug, Randy Smith nva, and run fuel with 10% nitro and 26% oil. It should run good enough to enjoy flying wit it. The violent vibration is from it fireing out of time. If you like running the old engines like I do, and can run open exaust, then us the McCoy
Phil        Tia,
        Frank McCune
Offline Ken Burdick
« Reply #5 on: October 16, 2017, 09:25:01 AM »
even the best fox will shake rattle and....you know.
One thing you might try is to find an out of balance prop and put the heavy side in line with the counterweight of the crank shaft. Other than trying to rebalance the engine, I'd get an LA .25
« Reply #6 on: October 16, 2017, 02:03:48 PM »
I'm not aware of any balancing "fix" for Fox motors.  If that were so, then a booming cottage industry would have developed to tame them.  I think Fox motors enjoyed some followers in the '50s primarily for their light weight, low cost, and availability.  No other good reason exists.
« Reply #7 on: October 16, 2017, 04:03:13 PM »
    There are multiple approaches with some pros and cons. Adding tungsten slugs to the counterbalance is probably the oldest but is definitely a mixed bag. It's probably a good idea for a profile because it can greatly reduce the vibration in the weak direction (while increasing it in the strong direction). For upright or inverted, I would say the results are ambiguous/dubious. The problem is the relatively heavy piston, which leads to...
   ABC cylinder/piston assy - this addresses the vibration better than the counterbalance modification, or in addition to it, because it reduces the reciprocating mass overall.
   The "High Zoot" crank addresses the possibility that the factory crank is not straight or eccentric, in addition to having more counterbalance.  People who really know what they are doing tell me this has much more effect than you would first imagine because most of the factory cranks are not quite right in the first place. It also addressed the crank breakage issue
« Reply #8 on: October 16, 2017, 07:06:32 PM »
Frank,
You fly the Fox 35 only because you want to fly a Fox. It does something for you to fly that engine, for some its brings them back to younger days, others just remember favorite ships they built and flew. Whatever your reason it is not to win the worlds. I use this engine in OTS just because I like the sound and I got a bunch of them.
The vibration you are feeling is a bit of pre-ignition. I have gone through this one. For me it was caused by having to much oil (29%) with to much nitro (10%) and a little to much prop (10x6) with a muffler. I wound up dropping the oil to 27% (50/50) and going to a 9x6.5 (old Top Flite 9x6 that I heat pitched up to 6.5). This allowed it to run in a lean 4 cycle with a good break and smoothed things out (all my Foxes have the stuffed bypass mod).
As to the add on's, the Fox needs a nose crutch built like its for an ST 60, hard maple mounts, cross grain balsa between the mounts, 1/16" plywood doublers (3/32" on profiles). This is the best way to handle the vibration. I use the stuffer backplate but don't use the high compression head, if you do you most likely will need to drop the oil to 25 - 26% (the high oil % increases the compression, old Drone Diesel trick). The ABC setup needs pipe fuel and lots of break-in. The High Zoot crank can help the vibration a bit but they are hard to fine.
Have fun.    DennisT
Offline Serge_Krauss
« Reply #9 on: October 16, 2017, 10:37:06 PM »
My 2 Foxes vibrate too much, but start easily and fly with the minor burp. I like my LA .25 much better, but for what I do with them, the Foxes are "OK." I do have a hefty tripler on the nose to keep structure intact over the long run and to prevent fuel from bubbling. That has been successful. The one thing I have never encountered is vibrations sensed through the lines. I don't think that should be expected, even from a Fox. inserting a wooden stick into the transfer is said to alleviate the "burping" problem in the Fox, but I haven't tried that.
The OS FP's and LA's are much easier on the planes. They don't "burp" either.
Offline GERALD WIMMER
    • Auckland Free Flight Club
« Reply #10 on: October 17, 2017, 03:17:20 AM »
Hello Frank my wife has a Shoestring with a 50thAnniversay Fox 35 with stock muffler on it that runs well. We did try a shinny case 1960's Fox 35 on it that had a lot of issues running rough and hot with a peace pipe muffler. She wanted to use another OS 35 and I was convinced her that a better model Fox 35 would work well enough which it has.
Another of her stunt trainers does have a modern BB ABC Thunder Tiger 25 that is a real smooth powerhouse with a lot more go then the old Fox but does not look or sound like a classic motor for a 'vintage' model.
Horses for courses I believe, like classic Hot Rods or Customs cars that use ancient Ford Flat head V8's and Y block Ford 272's or  312's or early Oldsmobile V8's 371' or 394's or Chevy w Block 348's or 409's,  none make any sense but are seen as fashionable motors to use now because they are different and have a heritage to them.
Regards Gerald
« Reply #11 on: October 17, 2017, 09:39:44 PM »
A Shoestring'd probly be a bit nose heavy with a Chev 409 in it .
7.5 mm intake and a Tornado 10 x 6 worn down to 9 1/2 ,floppy. Or the Black 9x6 & 9x4 work well on the Magnum 25 / TT FSR Clones , Gerald.
Thou the leaky Taipan Spray Bar is a intregal part of the ' burble ' . Seal the N V and it wont .
Spraybar above the case - at the outside tank edge laterally , sidemounted . And it richens low , leans off high , 4-2' s and other wonderous things.
« Reply #12 on: October 17, 2017, 10:25:39 PM »
Hi Matt   H^^
That Vimmy bomber replica that flew to Aussi had two Chevy 502 cu engines on it , they were light weights in power terms and had to be swapped out  ;)
Alina's Shoestring has a completely stock fox 50th anniversary.
That stunt trainer with the TT25 has my own set up with 5mm venturi and RC spray bar side mounted OS 732 muff with 10x4    #^
Regards Gerald
Offline Dennis Moritz
« Reply #13 on: November 15, 2017, 12:14:10 AM »
Could be the plane. Or plane/engine combination. Run the engine on a test stand. If it runs ok there, the plane/engine is setting up a bad resonance. Different ways to handle that.
Offline Robert Zambelli
Insidious crock of S**T
« Reply #14 on: December 01, 2017, 02:45:03 PM »
QUOTE: "At this point, we have people out there in the field torturing themselves for hours trying to get it to work, burp-quit-crash or shaking the airplane to bits in 3 flights, and then claiming how great the engine is."  :##
Really? You saw a plane shake itself to bits in three flight? Must have been built by some incompetent jackass.   n~
Are you trying to set a record for some of the most stupid posts on Stunthanger?  ???
You don't like Fox 35s? TFB.
Many of us like our old engines.
Maybe I don't like your $500.00 + power plants.
So what? I keep my mouth shut and don't bad-mouth them.
For what it's worth, I have many enjoyable flights with Fox 35s. Thousands, in fact.
I've NEVER tortured myself trying to get one to run.
I've NEVER had a burp-quit-crash, whatever that is.
I've NEVER had a plane shake itself to bits.
Re: Insidious crock of S**T
« Reply #15 on: December 01, 2017, 05:47:29 PM »
  Not only is this completely gratuitous  - since this is months old and unchanged since I posted essentially the same thing 20 years ago and many times since- I can only presume that you are taking this opportunity to ream me because you think you can get away with it while I am dealing with a fatal family problem. Quite a hero.
    Take your own advice and just ignore things you don't like. I haven't said a word about your "contributions", such as they are.
« Reply #16 on: December 01, 2017, 06:46:38 PM »
I have no idea what you're writing about. If you posted something regarding another issue, I did not see it as I rarely look at other subjects.
I'm expressing my opinion regarding what are, to me, offensive postings. I'm not "reaming" anyone.
I'm just bothered by people criticizing something I enjoy.
« Reply #17 on: December 01, 2017, 06:55:57 PM »
     I am writing about calling my comments that you quoted  an "insidious crock of sh*t" and accusing me of being "stupid"  - while I am trying to deal with a family issue that will end in the death of my father in as little as hours. It doesn't surprise me that much, it's consistent with what I have come to expect, but still, seems a little over-the-top to me.
« Reply #18 on: December 04, 2017, 06:43:15 PM »
No, I never accused you of being "stupid".
I said your post was stupid and I'll stick by my accusation.
For what it's worth, I consider you to be on of the most intelligent people on this site.
That's why I'm appalled by your post.
This site should be about enjoying our hobby.
Insulting people regarding their choice of planes or engines, referring to someone as a nitwit because he happens to like Fox engines, inventing stories - none of this has a place here.
Just my opinion.
Offline Ron Cribbs
« Reply #19 on: January 27, 2018, 10:42:18 PM »
If your Fox flew fine one day and changed the next then it’s probably not an internal/external engine balance issue of any sort. Yes they vibrate. Check to see if the doublers /fuse have cracked and ensure the mount screws are TIGHT. If you are 100% sure that the nose is solid then try putting thin aluminum strips between the engine and the hardwood bearers. Check to see if the wing joint is secure as well. A flapping nose will give you shakey lines
You could always run it on a test stand and see if the problem follows, but I suspect something went awry with the mounting or airframe.
Nothing wrong with a Fox .35 on a Shoestring. It’s been a good combo just shy of forever.
Offline David Ruff
« Reply #20 on: January 28, 2018, 10:54:37 AM »
Sorry, guys.  But I fly the Fox 35 with no issues.  I am old school.
I will put up with it.
I am not a competition flyer.  If I were, I suppose I would fly Stalkers and RO Jetts.
Or electric.
I chose to stay IC and old school.
Frank.  Keep flying the Fox.
Retired Army
Offline David Ruff
« Reply #21 on: January 28, 2018, 11:02:36 AM »
How many Champions and Championships were won with the Fox .35?  How many designs were built for the Fox .35?
I rest my case.
Retired Army
« Reply #22 on: January 28, 2018, 08:54:17 PM »
I think you Lack Balance .
You need a RADUGA 7 , to give you a sense of proportion .  ;D
The Olde Heavy Blade opposite the head , with the piston at T D C , might improve things .
if it makes it worse try the opposite .Only problem is how heavy .  LL~
Harmonics & other rubbish could come into it , head gaskets & plugs influencing these .
Offline David Ruff
« Reply #23 on: January 29, 2018, 11:17:28 AM »
By the way, Frank, I recently was lucky enough to find a new, never run Fox .59 Stunt motor.  I just ran it today for the first time on the bench.  Runs great.  Not sure when it was made, but it has a ringed piston.
It falls into the category of old Fox CL engines.
Retired Army
Offline David Ruff
« Reply #24 on: January 29, 2018, 11:19:27 AM »
Here is what you need:
Retired Army
Offline Ron Cribbs
« Reply #25 on: January 29, 2018, 05:22:34 PM »
Very nice! Beautiful sound too.
« Reply #26 on: January 29, 2018, 06:54:14 PM »
  Here is something that is a simple fix for a lot of the Fox shaking. I does work many times. Most people will scoff at it until they try it. When a fox is mounted inverted the prop is  flat across as the motor is starting compression.. On a profile the prop is now 90 degree out from the inverted motor and it will shake a lot more. If the prop is mounted vertical it will run smoother. It is harder to start and the prop can be broken easily as it will stop vertical. Having the prop mounted one forth rotation behind the compression helps keep the motor in balance.
EddyR
« Reply #27 on: January 29, 2018, 07:47:58 PM »
But the 59's got a INTAKE RESTRICTOR in it , when are you going to take it out .  ;D
This must be about 50 years ahead of its time . a Larry Scarinzi Trabant . Er Yatsenko . Um Little Thing with Big Injun .
Offline David Ruff
« Reply #28 on: January 30, 2018, 01:51:10 AM »
Matt; I did notice it has a restrictor.  What happens when I remove it.  I suppose I will find out.
I remember reading about Larry and Duke at the Nats.  Something about Duke stuffing basswood into the venturi????
At any rate, it is a blast having this engine.
Retired Army
« Reply #29 on: January 31, 2018, 04:57:16 PM »
Yes Indeed .
 ;D :## n~
Thinking Last Night on the Pig Skin Glove , from the building center . Good race pitman glove .
Bind the two fingers with blue 3M tape to avoid cutting the leather .
The Fox is fairly tame but reasonably ferocious .
Now a Big Combat Wing , with the Intake out , should be good for the Ton , easy enough .
Id half saw the bolts at bearer top level , tear a lug loose & its like having the intake out , with the crack under it you cant see.
Had the Peacemaker in the other post at the ton , like that . Crack under left lug .  >:( :(
