  • July 04, 2025, 07:39:25 AM
Author Topic: OS Max H40P  (Read 4305 times)
Offline RDJeff
OS Max H40P
« on: July 03, 2012, 03:02:51 PM »
I was the winning bidder on an FP40 on the Bay, only $17.95 for it, and when it got here today, I see that it's not an FP at all, but a Max H40P.  I looked at the OS history, and it appear this is an R/C pylon racing engine from 1967.  does anybody here have any experience with this engine?  I can see some possibilities for this engine, but don't know what it's running characteristics are.  I'll bench run it soon to get some idea, but would appreciate any input from the folks here.  Thanks!
Jeff
Re: OS Max H40P
« Reply #1 on: July 03, 2012, 04:52:15 PM »
Jeff
That was made as an OS 40H and was a good stunt engine, the Pylon version..not so much
Offline RDJeff
Re: OS Max H40P
« Reply #2 on: July 03, 2012, 06:55:18 PM »
Thanks for the info Randy.  Good thing I fly R/C too!
Re: OS Max H40P
« Reply #3 on: July 03, 2012, 07:06:46 PM »
Hi Jeff,
I have had one of those H.40P since my R/C days close to 30 years ago.  Put it on a Sweet Stick and hold on! LL~ LL~ LL~
It is a "hot" engine, even for later times.
BIG Bear
RNMM/AMM
Offline Brian Hampton
Re: OS Max H40P
« Reply #4 on: July 03, 2012, 09:03:30 PM »
The H40P was similar to the H40RR (Rat Race) except it was the only version of the first H40's to use twin ball races. All the others (including the RR) used a single rear ball race and a different prop driver that extended back into the crankcase where a ball race could be fitted. They're completely different to the later H40 which had a much larger transfer port.
Re: OS Max H40P
« Reply #5 on: July 03, 2012, 09:40:48 PM »
Hi Randy,
What sort of run did the stock .40H-Stunt have?  A wet 2 or a true 4-2?  How about props for the .40H-S?
Re: OS Max H40P
« Reply #6 on: July 03, 2012, 10:35:04 PM »
Hi Randy,
Setup correctly it would do either  4/2  or wet 2, they had the power similar to a ST 46,  Prop depended on what plane, A 11 x 6 or 11.5 x 5 would work well on planes of the era.
Offline RDJeff
Re: OS Max H40P
« Reply #7 on: July 05, 2012, 09:29:51 AM »
Does anybody know offhand what connecting rod will fit this one?  The big end is wallowed out... :-\
Offline Joseph Lijoi
Re: OS Max H40P
« Reply #8 on: July 05, 2012, 10:26:02 AM »
Don't you just love Ebay?
Offline RDJeff
Re: OS Max H40P
« Reply #9 on: July 05, 2012, 02:32:49 PM »
Usually I do!
Re: OS Max H40P
« Reply #10 on: July 05, 2012, 03:20:46 PM »
Hi
I have thousands of new parts for older OS  engines I can look for you if you want me too, I may have a new one
Offline RDJeff
Re: OS Max H40P
« Reply #11 on: July 05, 2012, 06:54:18 PM »
Thanks Randy, I would appreciate that.  I can't find any part numbers in the O.S. part listings.
Offline Jim Catevenis
Re: OS Max H40P
« Reply #12 on: July 30, 2012, 06:16:37 AM »
Randy - I just picked up a new in the box OS MAX 40H RC.  A couple of questions.  How can I tell what model of 40H this engine is?  The only markings, other than the H cast in the case are the letters RV stamped on the bottom of the mounting lug.  Also, what size venturi would be optimal for stunt and does this engine require any mods for stunt?
Jim
Re: OS Max H40P
« Reply #13 on: July 31, 2012, 11:35:34 PM »
There are two versions, old and new. The early version has a small transfer port and is the one that came in 4 variations. The OS timeline has a photo at http://www.osengines.com/history/osm640/osm-1964-max-h40rc.jpg
The later version has a much wider V shaped transfer port and was basically just an RC engine although it was probably available as CL with just a venturi fitted with no change to timings. Photo at http://www.osengines.com/history/osm640/osm-1972-max-40rc.jpg
From memory the two types had different bore/stroke so it's likely that the conrods were different as well. The letters stamped under the mount are probably only of interest to OS themselves (could mean anything) because two otherwise identical engines can have different markings. At a guess it might be a code they used to indicate the month and year of manufacture but I've never been able to make any sense from them (meaning I haven't cracked the code :) ).
Re: OS Max H40P
« Reply #14 on: August 01, 2012, 09:44:47 AM »
Jim
Hi Jim
Can you post a picture of your 40?
Re: OS Max H40P
« Reply #15 on: August 03, 2012, 03:48:50 AM »
Brian-Thanks for the info.  My 40H is the 1972 version.
Jim
Re: OS Max H40P
« Reply #16 on: August 05, 2012, 06:29:25 AM »
Randy-I was having problems posting the photos but Tim Wescott explained why. I am now able to post these photos.
Jim
Re: OS Max H40P
« Reply #17 on: August 05, 2012, 11:22:26 AM »
Jim
Hi Jim
You can use that one in CL Stunt, with a 265 venturie and 157 spraybar, you my want to use a lower pitch prop that a ST maybe a 5 or 4.5 pitch with a 11 to 11/34 inch diameter, Sometimes a 12 x 5 would be OK, depends on what plane your pulling
I would use 23% oil fuel with 1/2 castor, start with 5% nitro and go from there.
Re: OS Max H40P
« Reply #18 on: August 06, 2012, 05:21:00 AM »
Randy-Thanks for the information.
Jim
