  • July 12, 2025, 06:28:38 PM
Author Topic: OS Max-H 40 wrist pin  (Read 1385 times)
Offline Bill Johnson
« on: December 28, 2015, 11:42:34 AM »
Are these wrist pins supposed to be full-floating?
I just got one completely apart. Had to extract the wrist pin with a screw threaded into it. The reason I ask if they are supposed to float is because of the Teflon pads on each side.
Best Regards,
AMA 350715
Re: OS Max-H 40 wrist pin
« Reply #1 on: December 28, 2015, 11:37:46 PM »
yes if they have teflon or delrin pads on the end, they are  floating, even brass  pads are in some  OS engines
« Reply #2 on: December 29, 2015, 06:53:05 AM »
Thanks, Randy. I thought so but just wanted to make sure.
Even after multiple trips through the crock pot and a couple dips in decarburizing solution, it still took a lot of force coming out and seemed consistent until it finally popped out.
Best Regards,
AMA 350715
