  • June 22, 2025, 01:14:57 PM
Author Topic: Super Tigre G-21 .46...?  (Read 2808 times)
Offline joe renfro
« on: January 23, 2009, 07:45:45 PM »
Hi...I have been trying to get this carb equipped engine dialed in  ..running tongue muffler,10 x 6....runs good on high rpm..but won't idle without dying...Does the G21 46 have a chromed steel liner and aluminum piston with a single ring. If so...would this be safe to use synthetic lube fuel?  I know it has a ball bearing crank/
I am using a fuel I suspect may be the prob....5% nitro,,,20% all castor....OK...Is the all castor the prob? I was told yes..of course I was also told anything other than all castor would cause overheating and other nasty things and a ruined engine...
So,,,,what is the answer from the gallery...I figure among so large a group I will achieve enlightment.
Thanks....next round is on me...
joe
Online Robert Zambelli
Re: Super Tigre G-21 .46...?
« Reply #1 on: January 24, 2009, 07:37:44 AM »
Joe - we have run ST 46s with a variety of fuels: 5 and 10% nitro with 25% castor and similar nitro contents with 20 to 23% castor/synthetic blends, ALL with excellent results. The only downside to all castor is that it might foul the piston ring(s) with carbon after longterm use.
Although most of us use the 46 for CL stunt (no carb), I have test run a few RC versions and they idled perfectly.
Your issue could be fuel but I would also change the plug to a good idle bar RC plug.
Alan Hahn
« Reply #2 on: January 24, 2009, 11:59:55 AM »
joe
So I assume you are running a throttle on purpose. Low idle problems can be due to several things, one is that maybe you are trying to idle too low an rpm, the other is that a larger diameter prop (and heavier) will give you a better flywheel effect. Another benefit of a larger diameter prop is that if you also have a little less pitch, a higher rpm will still give a reasonable flight speed.
Next would be glow plugs---it needs to stay lit at low rpm even though less heat is being made---you might try a hotter plug or one with an idle bar.
Finally it could be the carb. Normally in CL we have that big open venturi hole, so small airleaks don't really amount to too much. However when you throttle down an RC engine, now you have only a tiny little opening to supply the airflow, so small leaks are proportionally worse. So check that the carb is sealed where it plugs into the crankcase--the o-ring can sometimes be pretty dried out in an old engine. Doesn't hurt to make sure the needle is  also sealed against air leaks. I assume you have been playing with the low speed needle or air bleed adjustment. So just in case you aren't aware, you set the high needle first, then the idle adjustment. The idle adjustment can be a pain because it can be difficult to do with the prop turning--so usually and safely it is best done with engine off--but as you know, that means you got to crank it up again, and again, and.........
added---because it is a ST 46 I assumed it is been already broken in. If for some reason this is not true, then usually the engine needs to be broken in with ring all wrung in before idle can be set reliably.
Offline joe renfro
« Reply #3 on: January 24, 2009, 12:35:31 PM »
OK..thx for all the info....so running synthetic blend will not harm this older engine...Maybe a little higher nitro and a hotter plug are the ticket..
thx again...
« Reply #4 on: January 28, 2009, 07:38:50 PM »
  Far from hurting it, I think you need some synthetic to keep the ring loose in the groove. And they really come alive with nitro.
     I am a little surprised at your prop selection, if we are talking C/L. I ran 12-5W, 12-6, 13-6, and even a 13-5. For really light airplanes you can go down in the 11's.
« Reply #5 on: January 28, 2009, 10:23:35 PM »
I have a NIB T&L G.21 .46 (sorry, Brett, it's not a cherry...but it's got a rilly good ring!), and I think Tom wants me to run 25% castor forever. I'll start with 10-29, and switch to 10-22. Meanwhile, Alan Resinger told me last summer that he's running YS20/20 in both his Stalker .66 (.67?) and the G.21 .46.
Personally, I can't see running that much nitro without stepping up to some sort of epoxy finish, which I'm not willing to do at this point (crash too much).  :P Steve
« Reply #6 on: January 29, 2009, 12:26:39 PM »
Hi Steve
Run what make ya happy, but all castor will 99 to 100% of the time stick the ring in the groove and kill off the engine power and run. seen it happen way too many times, I explain it in detail in the Engine article at the opening of this page.
It also does bad thing to the top of the rod :-(
Offline Don Curry AMA 267060
« Reply #7 on: January 29, 2009, 03:31:58 PM »
The old R/C trick for adjusting the idle goes like this.
1- open the throtle until you can insert a t-pin in the carb opening
2-open the high speed needle 1 1/2 turns
3-put a long piece of fuel tubing on the fuel nipple
4- put the fuel tubing in your mouth and blow through the tube and at the same time screw in the idle fuel adjust until the air stops
5- open the idle ajust1/2 - 3/4 of a turn
This will get you very close for the mixture ajstment. You need to readjust the high speed needle for wide open throttle but the idle shoul be close. If not do the fuel line pinch test at idle. If the engine dies immediatly the idle is too lean, open the idle screw about 1/8 of a turn and retry. If the engine continues to idle for a long time with the fuel line pinched it is too ritch, screw the mixture screw in 1/8 of a turn until you can let the engine idle with the fuel line oinched for 5 - 10 seconds.
Don
Offline Richard Edwards
« Reply #8 on: February 07, 2009, 06:41:44 AM »
Matter of interest is there any particular reason you are using an R/C carb on a controline model or did I miss something.
 First thing I would do is toss the carb in your spare parts drawer and get a venturi  assembly from one of the many people that make and sel them on this board, I really believe your running problems will be over at that stage.
