  • June 23, 2025, 02:32:31 AM
Author Topic: OS Max 46LA-S  (Read 1119 times)
Offline Dick Pacini
OS Max 46LA-S
« on: October 10, 2009, 11:09:00 AM »
What is the consensus on the OS Max 46LA-S engine?  How does it compare with the quality, power and ease of use of the OS Max 35 from back in the 70's?
AMA 62221
Offline Greg L Bahrman
Re: OS Max 46LA-S
« Reply #1 on: October 10, 2009, 04:40:33 PM »
Better all around. Nothing wrong with the 35S. It's just that the L.A.46 is user friendly, makes more power and mine is a one flip start. Last weeks contest I entered 2 classes and got 2 trophies. Can't ask for anything better than that. A lot of them are being used so there is a lot of good advice on these forums. They also can be run as a 2-4 break motor or run in a solid 2 or a solid 4 stroke just depends on what you like. The L.A.46 is a ABN motor and the 35S had a steel piston. Tower sells it for $79.99 you can't go wrong. Buy it, run a couple of tanks thru it, bolt it in and go fly. I have yet to hear a bad word on this motor.
Greg Bahrman, AMA 312522
Simi Valley, Ca.
Offline Neil Rogers
Re: OS Max 46LA-S
« Reply #2 on: October 10, 2009, 10:23:40 PM »
For the price you can't go wrong with an LA 46. It truely is a "flip and fly" engine.
Neil Rogers
Offline Matt Colan
Re: OS Max 46LA-S
« Reply #3 on: October 13, 2009, 07:03:52 AM »
An LA 46 is a great engine, very user friendly.  The OS 35S is also a nice engine, but the 46 just makes more power and is just a break it in, flip and fly kind of engine
