I have acquired a fox .35 with a hemi-head, stuffer back plate and an ABC piston and liner. My question is what i should use for fuel? Thank you Nick
Hi Lester
Below is a copy of my fuel article pinned at the top of this forum, I would suggest you read the whole things, however short answer is if I was you I would use a 25% total oil fuel with 1/2 castor 1/2 synth. This will keep the ABC part happy and not gum it up but will have plenty of oil for the small bushing in the case and the unbushed AL. rod.
I would like to tell you there is one Stunt fuel formula to run in all motors, I said I would like to tell you that…unfortunately this is not the case, and will never be as long as we have such a wide range of motors and running styles. What I will tell you is a good formula for the most common types of engines. Make sure you pick a fuel supplier who will give you consistent fuel day to day ,and will blend fuel for your motor needs or has fuel to match your needs. Stay away from any supplier who will not tell you the oil percentage, or who say one type works for all motors. I see this much to often also, It is unfortunate, but a lot of fuel manufactures will try to fool you about the oil and nitro percentage. One trick is to measure the oil by weight and all other ingredients by volume. Doing so, they can claim that the fuel is for example 18 % oil , when in reality it is only 14.9 % oil content. Using weight one for 1 ingredient and volume on the others does not equal 100 % . Other things are changing oil types, going to cheaper Nitro’s, and adding in other types of Nitro parrafins.
So what percentage do you try? For motors like Fox .35s, OS Max 35s or the old McCoy’s and K&B’s, use a fuel with 26 to 28% oil content; preferably half castor and half synthetic, up to 75% castor is OK. These motors have very small bearing surfaces, and are subject to much wear and heat, most are all plain bushing motors and most have unbushed rods. They need a lot of oil to help cool the engines. Since these motors run hot, they need extra oil to keep them lubed,clean, and to carry out heat . If you have one of these that is in very good shape but, is just starting to get some brown or black varnish plating on it, the synthetic mix will clean it up for you, resulting in increased life. Do not use the synthetic blend in an old motor that has a lot of time on it with all castor fuels; the synthetic will remove the castor varnish off the piston and sleeve and will in some cases, leave you with the worn-out motor that had to start with. Also always try to NOT use prop shaft extensions with these engine, as it adds a lot of wear on the crankshaft bearing.
