It's not as pretty. If it has the typical engine bearer arrangement, then the engine mounting is integral with the fuselage. This provides a lot of strength for the weight, which is prized in stunter construction.
Thanks much for the reply. I thought that
looks just may be the main reason.
The engine bearer is a good point, however so few airplanes use that anymore, I think I can do just as well with properly supported firewall mounting. While Stunters do use many high "G"s in the maneuvers both positive and negative, so do a lot of other models, especially Pylon Racers. When I did that, I broke a few wings, but never had a firewall come off.
Of course there are some of these RC ARFs that have engines come off the front, firewall and all. Too bad some of those guys know so little about stress and G loads, but they learn fast when the fingers and hand parts depart the body.
