  • July 04, 2025, 04:22:45 AM
Author Topic: OS Max .40H  (Read 2075 times)
Offline charlie
OS Max .40H
« on: April 12, 2006, 02:40:17 AM »
I have one of these. It is a crossflow (baffle) motor with a ringed aluminium piston. C/L version. Can anyone with experience of these engines tell me how they behave? Are they any use for stunt?
Thanks in advance.
Charlie
Charlie Stone  (The West Australian one)
Re: OS Max .40H
« Reply #1 on: April 12, 2006, 06:21:57 AM »
Thanks in advance.
Charlie
Hi Charlie,
Personally, I have never had a 40H, but there were a lot of people using them in the early '70s.  And some still are.
Re: OS Max .40H
« Reply #2 on: April 12, 2006, 10:03:04 AM »
Hi Charlie
That is one of the best stunt engines OS ever made, many people used them instead of ST 46s.
These were single by pass motors, with a baffled piston.
A 23 %  1/2 castor  1/2  syn.  works  very well in the motor.
If you run the motor in a nice rich 4-2  it will last a long time and give you many 100s flights
They have good power, a friend of mine flew a 630 sq in plane with his, with no problem. It would have pulled a larger one.
This would be a good engine for most ST 46 size  airplanes
Offline charlie
Re: OS Max .40H
« Reply #3 on: April 12, 2006, 06:17:23 PM »
That is what I wanted to know.  Thanks very much for the help.
Offline rustler
Re: OS Max .40H
« Reply #4 on: April 14, 2006, 08:47:58 AM »
Hoping I've got this right - It's worth remembering there are quite a few 40 motors with MAX-H on the side. For starters there are two basic configs. with different bores and strokes. The narrow bore ones are all lapped and single ballrace (I believe) and the large bores are ringed and double BB. Narrow bores come in at least R/C and RR versions, RR being Rat Race! This does not make a good stunt engine, but the R/C is pretty good for stunt? Don't know if any were put out as stricly C/L. R/C and RR appear in a little circle on the c/case somewhere.
The large bores were available in R/C and I don't know what else, but they were double BB and in the search for more power for the R/C boys, they became a little less friendly for stunt.
Ian Russell.
Re: OS Max .40H
« Reply #5 on: April 14, 2006, 12:46:49 PM »
Hi Charlie
The  ones I have here have MAX-H on the crankcase with OS under it.
It is a 1 piece case with dual ball bearings
The have a Steel liner, Alum baffled piston, with a ring
They have 4207  MADE IN JAPAN on the back plate and most, but not all have  KA stamped ubder the motor lug
They take the same  muffler as the  35S bolt on
These  are the ones that ran very well for us
A REV-UP  11 x 5 w  was  a good  prop for them.  There are  many  good props today
Hope this helps
Offline charlie
Re: OS Max .40H
« Reply #6 on: April 15, 2006, 07:56:42 AM »
Thanks Randy,  that description fits the engine that I have exactly with the exception of the marking under the engine lug.
Offline YakNine
Re: OS Max .40H
« Reply #7 on: July 28, 2010, 12:38:26 PM »
Randy do you sell a venturi for this engine I have a .40 R/C engine that I have never run and would like to convert it for C/L . Thanks T.J.
AMA 85135        GSCB
Re: OS Max .40H
« Reply #8 on: July 28, 2010, 01:07:46 PM »
Hi
Yes I can make those for you plus I have the NVAs that work that are PA style
Offline YakNine
Re: OS Max .40H
« Reply #9 on: July 28, 2010, 05:38:51 PM »
Do you want the engine sent to you for dimensions to verify fit ? Its not a problem UPS comes to my shop every day. Thanks T.J.
AMA 85135        GSCB
