Hi Charlie
That is one of the best stunt engines OS ever made, many people used them instead of ST 46s.
These were single by pass motors, with a baffled piston.
A 23 % 1/2 castor 1/2 syn. works very well in the motor.
If you run the motor in a nice rich 4-2 it will last a long time and give you many 100s flights
They have good power, a friend of mine flew a 630 sq in plane with his, with no problem. It would have pulled a larger one.
This would be a good engine for most ST 46 size airplanes
