  • June 21, 2025, 02:04:54 PM
Author Topic: LA46/Twister?  (Read 1796 times)
Offline Glen Wearden
LA46/Twister?
« on: February 23, 2007, 07:24:18 PM »
Is the LA 46 too much engine for a Twister?  The reason I asked is that when I built my Twister, I set it up with the Brodak mount system, but when I tried to fit a Fox 35, I realized I hadn't allowed for the backplate studs being so wide (about 1.5").  The LA 46 fits beautifully; though, and with a tongue muffler, it is only 9oz.  That's only about a half ounce heavier than the Fox with standard muffler.  Any opinions?..........Glen
Glen Wearden
Offline Russell Shaffer
Re: LA46/Twister?
« Reply #1 on: February 23, 2007, 07:29:17 PM »
Well, it should keep the lines tight.  If you do it, I would really like to know how it works out.
Russell Shaffer
Klamath Falls, Oregon
Online RC Storick
Re: LA46/Twister?
« Reply #2 on: February 23, 2007, 07:54:30 PM »
As long as it balances it will be fine. The engine turns the prop and the prop pulls the plane. Prop (or gear) it accordingly.
Re: LA46/Twister?
« Reply #3 on: February 23, 2007, 11:13:01 PM »
I agree with Sparky!  I have yet to see a plane that is "overpowered".  Some engines are so heavy that in certain designs it can make it impossible to balance "properly".  You can always get it to "balance", but it gets into the realm of the "barbell effect" that Mr. Gialdini wrote about years ago.  Without the right prop the plane can be too fast to accurately fly.
Getting the right engine run with the correct propeller is the whole key to any combination.
Offline Dennis Moritz
Re: LA46/Twister?
« Reply #4 on: February 24, 2007, 04:25:40 AM »
I saw a Twister outfitted with an LA46 this past summer. Propped right, it was a mild enough flyer, definitely stunt friendly. Surprised me. Since I'm accustomed to those engines lugging Cardinals, a considerably larger airplane. Legally, a 46 means .018 lines in competition. Sport flyers often fudge on this. Also, I've been to many local contests where line diameter is not checked. La46s are a little easier to rein in for stunt when compared to the 40. Of course many LA40s do fine. If anything the 46 is a tad lighter than the 40. The Twister is on the small side for stunt, by modern standards. ARF Cardinals, P40s, Pathfinder's, etc, have more wing area, probably thicker airfoils. They do all right with fox 35s, apparently 25s can work. I've seen those engines recommended at times for Twisters. 46s have lots more grunt, way more power. But go for it. Use a low pitch prop. The magic prop in Philadelphia is an 11 1/2 x4 apc. Follow the usual drill to keep modern engines from running away. Don't be shy about adding a head gasket. Run good fuel with enough oil (Powermaster 22% (50/50) 5% is what we use for almost everything.) Make sure your muffler flows well.
« Last Edit: February 24, 2007, 10:27:01 AM by Dennis Moritz »
Re: LA46/Twister?
« Reply #5 on: February 24, 2007, 09:52:52 AM »
Thanks, guys.  I plan to run a ProZinger 11/4 prop on it.  I run GMA10/22 in all my engines, except the Fox's; even my RC engines.  I'll try a GRW uniflow tank with muffler pressure.  I put the  Brodak end mounts on the tank so I can adjust it up or down, then securing it with rubber bands.  I'll try to launch at around 9000 rpm.  Should be fun!  Will report...........Glen
Glen Wearden
Re: LA46/Twister?
« Reply #6 on: February 24, 2007, 10:25:57 AM »
I think 9000 rpm is too low, it'll want to break hard and runaway. Try about 10,500 or a little over. Don't be shy about adding a head gasket. We usually set the engines by ear. A wet 2 stroke. I know the rpm for 40s is about 10,5000. I've flown plenty of forties. Just getting into the 46. Lots of club members use them. But like I said we set engines by ear, for the most part. The rpm is an estimate. Plenty of guys out there can give you an rpm figure. The LA46 is a very, very popular stunt engine with a no muss no fuss reputation. As soon as the weather breaks I'll put a tac on one of our sweet running 46s. This will be considered a desecration, a violation of tradition. Like using an electric starter. Well, I also use an electric starter. When I muscle myself to the line and flip out a tac, there'll be some verbal abuse.  VD~ Yeah!  LL~
Re: LA46/Twister?
« Reply #7 on: February 26, 2007, 03:31:05 PM »
I got the LA46 installed, but I'm afraid it is too far forward.  My mount system is forward for the short-nosed Fox.  After installing the tank, wheels, etc., I balanced it at the CG mark in the plans (about 2 7/8" back from the leading edge.  Had to add 2oz to the tail to get it close!  The plane weighs 45oz dry!  That's pretty beefy, isn't it?  At least I'll have plenty of engine.    Glen
Glen Wearden
Re: LA46/Twister?
« Reply #8 on: February 26, 2007, 05:21:44 PM »
Just wrote stuff about using a tongue muffler, to cut weight, well you are using one. So scratch that. Foam wheels can save a half ounce or so, over standard wheels. Why not try it. If you're not using those. A forty-five ounce Twister should be viable, pulled around by an LA 46. Otherwise, if you're confident about the glue joint for your engine mounts, get out a Dremel and grind some wood so the engine can be set back a half inch or so. Mounting points can be redrilled using a hand power drill, if you need to. Not nifty like a drill press. But line her up and let it rip. IT'S A TWISTER.
Re: LA46/Twister?
« Reply #9 on: February 26, 2007, 08:22:05 PM »
Thanks for the comments, Dennis.  There's enough room to bring the engine back about 1/4", but I'd have to move the whole mount back, or just mount the engine directly to the engine bearers, and that would mean extra holes, etc.  Foamies would be lighter, but there are a lot of grassburrs at one of the places where I fly;  foamies and grassburrs don't like each other; real hard to remove from the wheels.  I'm going to just fly it like it is, and if it does OK, I'll just keep on "keepin' on".  Will report.............Glen
Glen Wearden
