Hi, Dennis - thank you for the kind words!! I'm really pleased with the Saito engines.
I am presently flying the following 4-S setups: OS .20, OS Surpass .26 (2), SAITO .30 (3), OS .40, OS Surpass .40, Saito .56.
ALL of them have the carb locked open - I do not run any standard venturis. Why? As you heard mine run, you can understand that there is no need. I have always double filtered my fuel and have never had a problem with contaminants. The two engines that I referenced in my opening post belonged to a friend who sent them to me for troubleshooting.
BUT, there are a number of people who have experienced problems with 4-S runs, especially with the larger engines. This stems from tolerances on the barrel and bore of the carb - if they accumulate in the wrong direction, air leaks develop resulting in erratic running. THEN, you contact someone like Pat Johnston and order one of his excellent venturis and you're in business.
The Saito does not use an air-bleed setup as does the OS. The Saito has a small screw on the axis of the carb barrel. Adjusting this screw changes the distance (gap) between its end and the end of the spigot. If you look into the carb intake and turn the screw, you can see the gap change. Very simple, very effective especially in throttle response. Of course, since the barrel employs a helical drive, the gap changes with the throttle arm angle.
Regarding the "Batplane", three years ago, I mounted the engine, wired the carb wide open and after dialing in the needle, I've never touched it. Still has the original plug.
Come to think of it, I've NEVER had a plug failure in a 4-S engine.
Except for the OS .40 4-S, ALL my engines get the same fuel - Brodak 10/23, 50/50 (Also all my 2-stroke glow engines). Due to a lower compression ratio, the .40 likes a bit more nitro - I will change that soon by raising the compression a bit with a thinner gasket.
Internal modifications? NEVER!!! The guys who developed these little gems are topnotch engineers who really know what they're doing. Sure, a few ersatz engine "experts" think they can redesign the cams to improve performance - maybe they can, maybe not. I'll believe it when I see it. I have just enough experience with cam design to realize that it's way beyond my engineering capability. It's and extremely rigorous and expensive procedure.
BUT, if one of these "experts" succeeds and can prove that he/she has created a superior 4-S engine, my hat's off to them!!
I'll probably be so impressed that I'll probably buy dinner and drinks!!!!!
