  • July 17, 2025, 05:11:55 PM
Author Topic: OS MAX 15 III  (Read 1345 times)
Online Martin Quartim
    • StuntHobby
OS MAX 15 III
« on: January 07, 2010, 02:25:58 PM »
My brother gave me a OS MAX 15 III with little use, if any,  and I have a few questions about it.
I ran the engine on the bench and noticed it is leaking between the Steel Fins and the Crank Case, is that normal for this engine?
I noticed that there is  only 3 screws that go all the way from the Head  down to the aluminum crank case to hold the Steel Fin/Liner and 3 screws that only fix the head to steel fins, is that how it is
The conrod does not have a bronze bushing and I am afraid it wear down quickly, is there a better conrod available out there that is a match for this engine?
Will it need Teflon pads for the wrist pin like the OS MAX 35S?
Martin
Re: OS MAX 15 III
« Reply #1 on: January 07, 2010, 04:00:37 PM »
I've had several of those.  They are a great little light weight engine.  Some were run on high nitro with big venturis and bladders for F2D and they still didn't come apart.
I wouldn't worry about teflon pads or a bushed rod.  It's light weight plain bearing black fin engine.  It will last longer than you think.
Having 3 out 6 bolts full length is a bonus.  There were a lot of more expensive blackfin 35's with 2 out of 6.  These engines tended to blow a lot of cylinder-to-case gaskets.
« Last Edit: January 12, 2010, 08:17:21 PM by Paul Smith »
    • StuntHobby
Re: OS MAX 15 III
« Reply #2 on: January 08, 2010, 08:46:42 PM »
Hi Paul,
Thank you for your input. Did you notice in your engines any fuel leaking like I have described?
I have been looking for one of this Engines for some time and my Brother was kind to give me one. It is one of the lightest .15 I know and I plan to put to good use. Have a  few projects in mind for it:  Tiny, Nobler Jr. or Spitfire MK14 AeroFlite.
Martin
    • StuntHobby
Re: OS MAX 15 III
« Reply #3 on: January 12, 2010, 06:34:45 PM »
Can any one tell me if the OS 15FPS venturi will fit in it?
 Martin
Re: OS MAX 15 III
« Reply #4 on: January 12, 2010, 08:25:46 PM »
The FP/LA venturis will not fit.  The OD is .391".
The Max III needs a .351" OD.  You will probably need to make something out of alumumun, nylon, or even hardwood.  The are no beauty points.  The air only cares about the ID.
Leakage is NOT OK.  It should be a tight seal.  A little leakage is the step before totally blowing out the gasket, which woiuld be a bad thing.
One big problem with those blackfin engines was that, once run, the gasket becomes fused in place and you can't take it apart with destroying and replacing the gasket.  Since you can't get a new gasket, it's become a bigger issue.  So tighten it well and hope it doesn't blow.
« Last Edit: January 14, 2010, 12:42:20 PM by Paul Smith »
    • StuntHobby
Re: OS MAX 15 III
« Reply #5 on: January 15, 2010, 08:17:39 PM »
bummer!
replacing this gasket shouldn't be that hard. The engine ran once on the bench and when I saw leaking fuel I stop it.
I am thinking to disassemble the engine and use 0.012 aluminum sheet to make a replacement gasket and seal with high temperature silicone. Unless there is a better way to do this.
I have refurbished several engines but this one is a bit different construction. Some advise would be greatly appreciated.
Martin
Re: OS MAX 15 III
« Reply #6 on: January 15, 2010, 08:46:17 PM »
bummer!
    Might want to measure the piston depth at TDC, so you can get the cylinder back to the same place with the new gasket. There's not a lot of pressure on this gasket, so I would suggest paper or rubberized paper.
    • StuntHobby
Re: OS MAX 15 III
« Reply #7 on: January 18, 2010, 02:51:51 PM »
thanks Brett, I would have miss measruing the piston depth at TDC, before taking it apart.
Martin
Re: OS MAX 15 III
« Reply #8 on: January 19, 2010, 06:55:54 AM »
Not to worry.
Just measure the deck height and head depth when you put it back together and make sure you have a reasonable amount of clearance.  Like maybe .010"
