CLICK HERE--><--CLICK HERE
OS MAX .15 Gaskets
Started by Tres Lawton, October 24, 2026, 06:11:26 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Tres Lawton
Does anyone know if the OS MAX - III .15 head gasket and backplate gasket will fit the later OS Max .15 engine? And or where to purchase?  I am reworking / cleaning up a newer OS MAX .15, and the gaskets seam harder to find than the older MAX III gaskets.
Tres
   Well, i would think the back plate gasket would be the same, just going from memory of looking at the engines I have. I don't know what the head gaskets for each consist of, but they may be the same also if they are soft aluminum. The venturi is still a small o-ring, I believe. If you have an example of each, and between the have examples of everything you need, just test fit them on each engine. BAck plate gaskets can be made fairly easily. A metal head gasket can be cut from soft aluminum also, you just need to know the thickness you want. Lay out a center, scribe the inside diameter, and the outside diameter as carefully and accurately as you can. Cut the inside opening first, I think, with a compass that has a sharpened cutter  on it, or even just by hand by making slow, multiple passes with a new exacto blade in your knife. I really doesn't take too long to cut through, and then you can clean up the inside and test fit on the head. Outside can be trimmed with scissors. I've cut head shims and gaskets from soda can stock this way before, but that material is pretty thin usually between .004" and .007" thick, but they can be stacked up for the proper head clearance also. WIth all the home laser cutting equipment out there, maybe they can be laser cut?? There are also several vendors on eBay that off gasket sets for vintage engines, and you can investigate that possibility.  Goodluck with the search!
Tres Lawton
Many thanks Dan!  Will keep searching or making.  I am working on Sig Akromaster that will get the OS MAX 015 on it.  This engine was my first BIG engine back in the 70s and I would like to revisit old times.
Tres
Robert Zambelli
Tres - forget paper gaskets - use this.
NOT for head gaskets!!!
Tres Lawton
Many thanks Bob.  Will give it try.
Tres
Motorman
There's a guy on eBay that makes paper gaskets for many model engines. He might know about interchangeability and maybe have a set you can use.
https://www.ebay.com/itm/175561438232?itmmeta=01M5SPHXJ3K861N9AN2J4Z7PM4&hash=item28e046f418:g:g2AAAOSwTOJjtkNL
MM :)
Tres Lawton
Thanks MM
looks like he has backplate and head gaskets that will work.  Do you have an opinion / experience on the paper type head gasket in leu of aluminum?
Tres
Brett Buck
Quote from: Tres Lawton on October 25, 2026, 07:40:46 AMlooks like he has backplate and head gaskets that will work.  Do you have an opinion / experience on the paper type head gasket in leu of aluminum?
   Are you sure it is aluminum to begin with? It was not uncommon to have fiber head gaskets back in the good old days.
Quote from: Tres Lawton on October 25, 2026, 07:40:46 AMThanks MM
Tres
  If the gasket is made from the right material, a paper head gasket can work well on a small engine. That asbestos gasket material that Perfect used to sell would be appropriate  because the head develops more heat than a back plate. I've seen both in McCoy Red Heads and even in some old Fox.35s that I have taken apart. Might be as reusable as a metal gasket, though. I think they are worth a try.
Tres Lawton
Quote from: Brett Buck on October 25, 2026, 11:30:31 AMAre you sure it is aluminum to begin with? It was not uncommon to have fiber head gaskets back in the good old days.
Quote from: Dan McEntee on October 25, 2026, 12:16:33 PMIf the gasket is made from the right material, a paper head gasket can work well on a small engine. That asbestos gasket material that Perfect used to sell would be appropriate  because the head develops more heat than a back plate. I've seen both in McCoy Red Heads and even in some old Fox.35s that I have taken apart. Might be as reusable as a metal gasket, though. I think they are worth a try.
I am sure the currently installed head gasket is aluminum.  Also, I think I will give the paper gaskets a try, as they are not terribly expensive (approx. $21.00 for 2 of each shipped).  The eBay listing says the head gasket is .33mm Karropak material.  Not sure what Karropak is.  Any idea.
Tres
Dave Hull
Karropak is just the common fiber-cellulose material that is carried in all the car parts stores like NAPA. I have used the thin stuff for backplate gaskets (especially when the engine surfaces are rough) and the thicker stuff for steel-fin seals to the case. I haven't used it for a head gasket. Might work.
The more modern OS engines used what translated as "vegetable paper."  Again, a cellulose fiber type material, but much finer fiber and much thinner gaskets. When the rod end clearance is there, I have used drafting vellum for that. Mylar sheet works also. Obviously, it is easier to order them laser cut....
Motorman
I always wondered about his paper head gaskets but never felt compelled to try them. Let us know.
If you want to know if a head gasket will fit from another engine you can check the bore size. If they are the same then it's a good bet the head gaskets will work in either engine. Bore size info is usually in the manual.
You can trim the OD of a gasket with some sharp scissors but it's much harder to change the ID.
Are you building a Max III or something else? Parts from OS LA are what you're looking at right?
MM :)
Tres Lawton
Quote from: Motorman on October 26, 2026, 12:50:23 PMI always wondered about his paper head gaskets but never felt compelled to try them. Let us know.
MM :)
I am working on an old OS MAX 15 that will go on a Sig Akromaster that's almost completed.  Max 15 came out around 1975 between the MAX III and the FP designs.  I have been searching on eBay for OEM parts (gaskets) for the OS MAX 15 with not much luck.  However, there are some parts for the MAX III out there.  Was able to find a new MAX III rod that according to Sceptre (Peter Chin) are interchangeable.  Was not sure about the gaskets being the same.  So, I have ordered some paper ones for the MAX 15 from site you referenced in this post.  Should have them this week and bench run this weekend.  Will post a report on fit and performance of the paper gaskets as soon as I get her runin.  I have the original NVA and venturi that came with the MAX 15, so hoping for good old Akromaster / OS MAX 15 combo to bring back some teenage memories.
Tres
Steve Helmick
Backplate gasket is easy enough. Find some kind of thin cardboard or thick craft paper, use a compass to draw the circle, cut it out with a #11 Xacto. Stick the backplate through the hole, mark the holes and punch through the loc's with an awl or scribe. Install the backplate and then cut the outside with the Xacto. You can oil up the backplate and let the oil mark the outline and cut with scissors. Same for cylinder base gasket on engines like the OS Max Mark 1>3, K&B GH, steel fin Fox .15's and the Johnsons, but keep in mind the timing gets more mild with a thinner gasket there, or higher timing with a thicker base gasket. Which reminds me, there's a guy in Oregon that makes a brass shim to jack up the timing on Max III's and also a head for them that uses Nelson-style glowplugs for Free Flight guys. If you want his contact info, holler.
I wouldn't mess with fiber head gaskets, because there are some good options in copper or aluminum. Most .15's have the same bore, so it's likely you can use a ST headgasket or FP .15 head gasket on a Max III, etc. Fox, Cox Conquest, whatever. Check around for engine tests to find actual bores before spending your $. There is another alternative, and that is cutting your own from beer can or soda can. A small drafting divider with one modified needle made to cut works, but takes some patience. Likely thinner than an actual head gasket, so you'll end up with higher compression or maybe need to stack a few in there. You might also take a micrometer to the local hardware store and look at their aluminum flashing and furnace ducting. That stuff is very soft and would work fine. Use flower clay to check for piston clearance! Steve
Tres Lawton
Paper head gasket test.
I got the paper head gasket and backplate gasket for the OS MAX 15 today.  They came from ICBIM Products on eBay that MM referenced earlier in this post.  I bench ran the engine three times with about 1.5 oz. fuel for each run. I had to re-torque the head screws after the first two runs.  On the third run I installed the muffler. The head screws remained tight.  The backplate screws did not ever loosen.  No leakage was noted during or after the three runs.
While I had the head off, I checked the fit of an FP 15 head gasket.  The ID was perfect and the OD would have to be trimmed to fit.  I plan to run the paper head gasket for a while just to see if or how long it will hold up.  But will probably trim an FP 15 aluminum gasket just in case.
Tres
Steve Helmick
Quote from: Tres Lawton on November 02, 2026, 03:19:26 PMPaper head gasket test.
Tres
Small moon-shaped divots for screw clearance should be all you need to trim. I'd plop the gasket & head in place and scribe through the holes, remove and then use round jeweler's file to make the divots. Where there's a will, there's a way! I have a Max III .15 that I need to build a Dixielander FF for.  Steve
Dennis Toth
Steve,
You might fine what you need at this eBay site:  https://www.ebay.com/str/rcgasketcompany
Best,   DennisT
Steve Glass
I use sticky-back aluminium foil for all my gaskets. The stuff used to seal ducting. just stick it to one of the surfaces and cut around with a sharp knife
very good for sealing the engine to silencer joint so should work as a head gasket?
steve
Like Like x 2 Agree Agree x 1 View List
Roy Lane
Check with Bob Brooks at The Control Line Store on EBay. He has lots of engine parts esp for OS and Enya. Best to call him. Has never let me down.
