  • July 06, 2025, 11:24:11 PM
Author Topic: OS LA46  (Read 997 times)
Chris Wellington
OS LA46
« on: August 28, 2007, 11:42:26 AM »
Apologies if this has been covered previously but I have an R/C LA46 (blue) ; I was planning to convert to stunt but was told that the timing is different on the r/c version : is this the case? Thanks
Offline Bob Zambelli
Re: OS LA46
« Reply #1 on: August 28, 2007, 11:56:33 AM »
Timing is the same - put in a venturi and OS needle valve and you're all set.
One fine engine - no need to change anything but the above.
Re: OS LA46
« Reply #2 on: August 28, 2007, 01:28:04 PM »
FWIW here at 2500 feet altitude my setup (works on the coast as well) I use an APC 12.25 x 3.75 prop, powermaster 10 - 22 with an extra 6 oz of castor added to the gallon. Uniflow tank, at home feild uses just under 4 oz, at contests out west, (less than 300 feet altitude) I tend to use 4.25 or a touch more fuel. The one thing I have fought is the fact that a couple hundred rpm low and it sucks fuel REALLY fast, a couple hundred fast and it will run all week. but if you get it right it is a very good solid performer.
Re: OS LA46
« Reply #3 on: August 30, 2007, 11:11:44 AM »
I have seen successful set ups with the stock LA 46 using the 12.25 X 3.75 APC to wood 11-5s and a lot in between.  Very friendly engine and I think much better for stunt than the stock OS 40 LA.
