  • July 18, 2025, 09:14:13 AM
Author Topic: OS LA-46 straight Venturi  (Read 934 times)
Offline Christopher Root
« on: January 19, 2020, 08:41:20 AM »
I’ve got a LA-46 R/C that I would like to convert to C/L.  Where can I get a straight Venturi and NVA?  How about a metal back plate?
Offline Peter in Fairfax, VA
Re: OS LA-46 straight Venturi
« Reply #1 on: January 19, 2020, 01:58:32 PM »
The LA 46 is a nice engine.  Had a good season with mine.  Comments follow, some a repeat.
Venturi:  The O.S. is just fine, but the aftermarket ones are also good, and offer more choices as to diameter.
NVA: The PA is good, as is the Super Tigre.  However, the O.S. and the Enya, while adequate, do not match my style.  Further note:  If installed on a profile plane, bend over the needle or cut it and install a squared wheel collar so it is really, really short.  That way, it will survive inverted landings.
Further notes:  There is a pinned article on this board regarding setup, if that helps.
Offline Geoff Goodworth
« Reply #2 on: January 20, 2020, 04:26:04 PM »
For most applications, the standard OS venturi (7.1mm ID) is too big.
The FP 20/25 venturi fits and is 6.55mm ID. That is probably too small. My LA 46s are very happy with the FP 20/25 venturi reamed out to 6.75mm ID — the same as the small venturi that used to come with early FP 35s and FP 40s.
All these numbers are for engines using the factory OS 3.5mm OD spraybar.
