  • June 17, 2025, 01:11:43 PM
Author Topic: Hey - 1/2A Experts: Tank size for the BigMig .061?  (Read 1346 times)
« on: June 05, 2019, 08:17:10 PM »
A question for our 1/2A experts....
So, I'm trying to get ready for Brodaks 1/2A stunt event.  What tank size will get me through the stunt pattern?  Also, recommended prop?
Thanks!
Online Carl Cisneros
Re: Hey - 1/2A Experts: Tank size for the BigMig .061?
« Reply #1 on: June 05, 2019, 11:09:45 PM »
Scott
1 oz tank (and you can then adjust the amount needed)
5.5x2.5, 6x2, 6x3 apc props
fuel wise:  15% nitro with 20-22% oil
Carl
OR, you can have some of my 60% nitro fuel and run a 2 oz tank on it.......   VD~ VD~ VD~
Carl R Cisneros, Dist IV
Control Line RB
Offline John Lindberg
« Reply #2 on: June 06, 2019, 08:09:18 AM »
I think "global warming" has caused your brain to malfunction, Scott! 1/2a?  HB~> HB~> HB~> HB~>
Offline Peter in Fairfax, VA
« Reply #3 on: June 06, 2019, 08:10:55 AM »
Scott,
If you need a tank in that size range, I have several boxes of them.  Not sure any are uniflow, though.
Peter
« Reply #4 on: June 06, 2019, 11:26:42 AM »
No, it went plenty fast on 20%.
« Reply #5 on: June 06, 2019, 12:01:10 PM »
Not possible!  I wear my tin-foil skull cap morning, noon, and night!!
« Reply #6 on: June 06, 2019, 01:10:57 PM »
aww, come on Scott, I think I still have a header and pipe that will make the Norvel do the pattern in maybe 30 seconds............   VD~ VD~ VD~ VD~ VD~
Control Line RB
