  • July 03, 2025, 10:09:05 PM
Author Topic: OS LA .40 CL, Four questions?  (Read 1739 times)
« on: May 10, 2012, 08:59:45 AM »
I have this NIB OS LA .40 for The New American.
1) It appears as though I have to drill the needle valve hole to fit a common needle valve bar assembly, as the bar is a bit larger in diameter. Correct?
2) What assembly are they using? I have a few.
3) Tongue mufflers, what are they using?
4) Most common one?
Someone told me Aero Products ruled!
Charles
Re: OS LA .40 CL, Four questions?
« Reply #1 on: May 10, 2012, 09:46:55 AM »
What is a "common" needle assembly?  My OS40LA uses an OS 25 needle assembly and a tongue muffler from "Big Art".My usual fuel is SIG 10-10-10.  Prop 11-5 Y&O.   That seems to work.
« Reply #2 on: May 10, 2012, 10:37:42 AM »
What is a "common" needle assembly?  My OS40LA uses an OS 25 needle assembly and a tongue muffler from "Big Art".My usual fuel is SIG 10-10-10.  Prop 11-5 Y&O.   That seems to work.Floyd
Floyd,
I probably should have said "most common brand."
What if I said "most common prop?"
Did you drill anything out?  Who is "Big Art." Got a photo of the muffler?
Charles
ChrisSarnowski
« Reply #3 on: May 13, 2012, 09:33:42 PM »
You can read about Big Art there: http://www.modelaircraft.org/files/AdamisinArthur.pdf
Big Art is the Chuck Norris of Control Line.
You have to drill out the case of the LA 40 if you want to use a Super Tigre type needle valve. If you use an OS needle valve of recent vintage, then no drilling is needed.
If you want to see some muffler pictures then go to the Brodak web site and search for "tongue".
I think I was using an APC 11-5 on mine.
-Chris
Online Tim Wescott
« Reply #4 on: May 13, 2012, 09:36:05 PM »
I can't answer for Floyd, but I'd reply "most common prop where?"
Use a spraybar that fits.  Don't hack up your crankcase.
Offline Steve Hines
« Reply #5 on: May 25, 2012, 10:37:05 PM »
I just put one together with the new enya pro nv and a derlin venture. you have to shim the nv to get it in the center and drill out the hole a little bigger. I used the info from pampa on total area. It is one of the best engines I have. Im using a 10-5.
