Engine basics => Engine set up tips => Topic started by: Dennis Toth on November 28, 2021, 07:07:39 PM
Title: OS gasoline glow plugs - Glow G5 Gas Plug: GGT15
Post by: Dennis Toth on November 28, 2021, 07:07:39 PM
I don't know if this is old news but I came across these OS Glow G5 Gas Plug: GGT15 that supposed to run gasoline/oil fuel. They are not cheap ($18 per plug from Tower). They say you can't use them with nitro fuel. Anyone try these yet?
I wonder if you run a high rpm/low pitch set up it could work and really cut the cost of fuel. Also, would cut down on the amount of fuel needed per flight (like half what is needed with low nitro fuel). Interesting cause this would reduce flying weight and CG shift.
Best,   DennisT
Title: Re: OS gasoline glow plugs - Glow G5 Gas Plug: GGT15
Post by: M Spencer on November 28, 2021, 08:28:06 PM
Wondr if youd need Av Gas .  VD~ LL~ S?P
Post by: Reptoid on November 28, 2021, 11:22:35 PM
Best,   DennisT
     Even if it does work well, I think you will be woefully disappointed in the power output on gasoline/oil mixtures. It will produce 20% less power than straight methanol/oil., and 25%-30% less than 5% to 15% nitro fuel that most are running for sport/stunt. It also runs considerably hotter and likely would require reduced compression due to the flame speed and the lack of vaporization cooling of gasoline.
     But hey; if you try it, let us know how it worked out.
