  • June 22, 2025, 10:45:48 PM
Author Topic: PA-51  (Read 1191 times)
Offline Scott B. Riese
  • Just a student of stunt
PA-51
« on: November 27, 2009, 11:10:27 PM »
I've run the PA-51 on a pipe, LOVE it  H^^...NOW I want to try it with rear exhaust. Is there anything different or changes I should know???
Scott
Scott Riese
Portland, Oregon
AMA 528301
Re: PA-51
« Reply #1 on: November 28, 2009, 09:09:05 AM »
Scott
Hi Scott
No they are the same motor ,timing, et all  . just use the same size venturie and shims and it will run identical as long as they are the same series, If you have one with a differant head , you will need the appropriate shims
Re: PA-51
« Reply #2 on: November 30, 2009, 06:24:08 PM »
Thanks Randy. I have a series of shims from you. Do I add to the case side or the head side IF I NEED TO?
Scott Riese
Portland, Oregon
AMA 528301
Re: PA-51
« Reply #3 on: December 01, 2009, 09:29:48 AM »
Between  the  head and the top of the sleeve
Re: PA-51
« Reply #4 on: December 01, 2009, 09:43:42 AM »
Thanks Randy...ONE MORE thing....Do you Carry (sell) RE-Mufflers? I didn't see them on your web sight.
Scott Riese
Portland, Oregon
AMA 528301
Re: PA-51
« Reply #5 on: December 01, 2009, 06:22:17 PM »
Yes I always have, there are 2 types, Header mufflers, and slide on tube mufflers, these are both cnc lite weight products.
There is a picture of both on my web site on the new product page
The lite weight cnc slide on tube for RE engines will slide on and seal to any standard 3/4 inch header
