Engine basics => Engine set up tips => Topic started by: Steve Dwyer on June 30, 2018, 08:43:18 AM
Need help I want to convert an RC FP 40 over to control line. I need the tower part numbers for the OS NVA assembly, Venturi and head gasket. I did this several years back to another FP 40 and have misplaced their numbers, can't seem to find what I'm looking for on their site. Want to put this motor on my new Fancherized Twister.
gasket set is; 23364000, venturi is; 2331200 and NVA is; 26582900
I prefer the 25 size venturi;22312000
Good luck, Jerry
PS: You can call them toll free at; (800) 637-6050 for order assistance.
Thanks Jerry
Jerry,
Their site is awkward to navigate with a part number I guess I'll have to call them after all. I even found my past order history and searched the part numbers with the response saying the number is no longer valid. I hope these parts are not discontinued especially the NVA. Have you ordered using these part numbers recently?
I ordered the NVA in April of 2017, I just checked my order history and the part # is invalid. I would check with Randy Smith, if he doesn't have the OS part his PA NVA is a very high quality part.
Hi Steve, actually it's been a while since I ordered any OS parts.
Good luck, Jerry
Send it to Jim Lee. He will return a ready to go motor at a very reasonable price. He's converted at least 20 engines for me. Actually he usually stocks these parts so you might just get the parts and do it yourself.
https://www.osengines.com/parts/xr13342.html
Check Against the PICTURES .
They have been discontinued by OS , but you can use some of the LA venturis, the OS NVA has also been discontinued, I have venturis in stock, and I have managed to buy a few more OS NVAs, but I have plenty of PA NVAs in stock, they are much better but you would need to drill your case to .157 to accept a PA needle, or if you use the ST , Enya, or OLDER OS NVA, as the old ones are .157 and the LA and FP uses a 20 size needle that is .135
Randy send me a PM I'd like buy a PA for the OS FP 40. I have no problem drilling out for the larger diameter.
I can do that but you will need to use the .281 diameter venturi and NOT the .255 one
