  • July 07, 2025, 11:29:10 PM
Author Topic: Thunder tiger .15  (Read 930 times)
Offline YakNine
Thunder tiger .15
« on: February 24, 2011, 12:08:00 PM »
I just bought a few series 21 McCoy's nib off the bay that the seller got at an estate sale and he threw this in with the bunch it was castored tight but a little liquid wrench and the heat gun loosened it right up. I am going to dissasemble it as I am sure the rod is stuck on the wrist pin it seems to have good compression though. I was wondering if anyone had any experience with one of these engines. I am thinking about using it in a Perky for the postal contest and if it runs good maybe a Junior Lightning Streak or one of Kieth Sandberg's Challenger .15's. I am going to use an AP Yellow Jacket venturi and needle valve on it, it came with an R/C carb and a muffler but I have a Magnum .15 muffler that bolts right up and is  lot lighter. I was just wondering if anyone had any experience with one of these engines. T.J.
AMA 85135        GSCB
Re: Thunder tiger .15
« Reply #1 on: February 24, 2011, 12:18:53 PM »
No experience with one, but looks kinda "Enya'ish"!  If so, it should be pretty strong for its age and size.  Maybe not a match for a OS .15FP, but still more than say a Fox .15X.  Seems all the knock offs copied one Japanese engine or another.  Which isn't "bad" as long as decent quality is present.
Big Bear
« Reply #2 on: February 24, 2011, 01:38:47 PM »
That is a very old 15 , about 30 Years old, Thunder Tiger made in Tawain, If it is in good shape it would be good on a Ringmaster jr. or the like
« Last Edit: February 24, 2011, 03:43:46 PM by RandySmith »
Offline YakNine
« Reply #3 on: February 24, 2011, 02:50:28 PM »
I haven't looked at the insdes yet but it seems to have good comprression I will know more after Itake it apart and give it a good methanol soak and scrub down. I haven't weighed it but it feels twice as heavy as a 15X. T.J.
AMA 85135        GSCB
