Hey gang. I picked up a couple of Enya .15s on E-Bay, for use in Akromasters and similar smaller planes. One is a -II, and the other is a -III. I gave them both a run on the test stand the other day, just for testing purposes. I used a Master Airscrew 8x4, which is an older wide-blade style. I was using some K&B 100 fuel that is 5% nitro and 20% castor oil. The -II ran great, right up to 12,800 when leaned out. The -III was a little bit harder starting, but ran up to 14,300 when leaned out.
I've already bolted the -III into a Stuntin' Junior Ringmaster that will get it's maiden flight this weekend. This plane is now 16.9 oz., ready to fly. How does this sound for a setup? Do the Enyas like to be run in a wet two-cycle run, or do they have a 4-2 break. They seemed to like running two-stroke style on the stand.
