  • July 17, 2025, 04:47:45 AM
Author Topic: OS 46LA-S Carb  (Read 1014 times)
Offline Jay Wood
OS 46LA-S Carb
« on: July 12, 2009, 02:38:57 PM »
I was wondering if anybody knows if the venturi carb on the OS .46 LA-S will fit the OS .46AX. I have a AX I'd like to convert to CL. I've contacted OS tech support today(Sunday) and probably will get a response sometime this week but I thought I'd ask you folks first.
Jay
Re: OS 46LA-S Carb
« Reply #1 on: July 12, 2009, 04:46:11 PM »
The AX uses a large, two needle carb.  The LA uses a much smaller, airbleed carb.  I'd be amazed if the two interchange.  The AX carb mount is at least 2mm larger than the LA.
Offline Jay Wood
Re: OS 46LA-S Carb
« Reply #2 on: July 12, 2009, 05:40:42 PM »
Thanks Phil,
I guess the AX is headed for eBay
Jay
Re: OS 46LA-S Carb
« Reply #3 on: July 13, 2009, 08:26:32 AM »
Contact Jim Lee at Lees Machine here in the vendors corner.  Or any of the fine vendors we have on this site.  DOC Holliday
Offline Jay Wood
Re: OS 46LA-S Carb
« Reply #4 on: July 13, 2009, 03:19:44 PM »
Thanks for the referal John. Jim had a affordable solution in about 5 minutes.
Jay
