  • July 30, 2025, 05:52:36 AM
Author Topic: os 46fs  (Read 9713 times)
Offline George Waters
os 46fs
« on: November 02, 2024, 09:49:46 AM »
I have been offered one of these and was wondering if they can work as a stunt motor.  George
Re: os 46fs
« Reply #1 on: November 02, 2024, 10:33:34 AM »
   FS or SF?
Re: os 46fs
« Reply #2 on: November 02, 2024, 04:40:25 PM »
He said fs but he could be wrong as he is an electric flier.  George
Re: os 46fs
« Reply #3 on: November 02, 2024, 08:11:20 PM »
I think Tom Muggleton is playing with an OS .46SF. Not sure what, if anything he has done to it. If I had to guess, I'd say more muscle that the .46LA, but might take some work to get it "stunty?"
Re: os 46fs
« Reply #4 on: November 02, 2024, 08:33:18 PM »
Myself, Jim Lee and a few others used it -stock-as a stunt motor for a few years.  Yes a lot more power than an LA but also heavier.  Jim used his for at least ten years,   I gave up after a couple.   In my case they chewed up rods in a hurry.   Had to replace them about every 50-60 flights.   I concluded there was some internal misalignment problem putting extra stress on the rod.  I think that is when I went to the Wiley .40 and pipe and sold my .46 SFs.
Offline Peter in Fairfax, VA
Re: os 46fs
« Reply #5 on: November 02, 2024, 09:39:38 PM »
I've been running the SF 46 several seasons.  Much stronger than the LA 46.  No rod issues for me.
Peter
Re: os 46fs
« Reply #6 on: November 03, 2024, 11:46:44 AM »
Assuming it is an OS 46sf, and it is **unmodified**, they are very powerful, easily a match for a 45FSR. I don't have one but I have seen quite a few of them, use typical 46VF props like a 11.5-4 3-blade, etc.
Re: os 46fs
« Reply #7 on: November 03, 2024, 02:19:17 PM »
Thankyou one and all for the info. I should have it next week and i will let you know for sure what it is and how it runs.  George
Re: os 46fs
« Reply #8 on: November 03, 2024, 10:18:05 PM »
Clone 9 royal . 46 ( its now in a OS case ) Eye Denical , bar its notta ' S ' . Only 80 Ounce . with a 2 x 6 . Short Adamisin tube muffler - suction . 15 % Nitro .
As it was a bit short , we putit IN two clicks . where OUT two ( four back from there ) woulda gottit spot on . And run out . as its only 6 ounces .
Eye Dentical Perfomance to a P D P 4 round head S Tigre 60 . In that Id messed around and got nowhere , till that set up .
Seems to like the Master 12x 6 wood . Have used it in the Spit & P-51 on 10 % as theyre not quite as heavy . Can be quite economocal then .
Theyre kinoff a side exhaust VF , sme era, anyway . Used a 9 m.m. ! / .320 in. INTAKE , there . .312 in the others .
Bob hunt used that in the FSR , so if it were a FSR - S ( which dont exist ) a 4 inch pitch , gets ' the switch ' -
Usually you have a ' Flow Through ' cowl asinthe HOLE above the C' Cae - or side vents up top , so they dont get stuck roasted & lean . For either Type .
The AX & FX arepretty much tarted up ' S F ' s  . Theres a ton of CLONES too , all the parts interchange . a VF has a 16 m.m. crank whereas  a 15 m.m. is in the SF .
 OS 45FSR & OS46 SF
  I was given a stunter without a motor that originally had an OS 45FSR in it .  Went thru my stock of motors and nothing matched
the mounting bolts. Then a friend offerred me an OS 46FS that was set up by Tom Muggelton and it fits the plane well . What are the differences in these motors in how they run .
Hi Bill
Both motors are fairly powerful ones, They will turn a 13 inch 2 blade or 12 inch 3 blade and need to be loaded, Try not to run a very small prop, They both can be made to run a very nice powerful high RPM 4/2, depends on which one you have, I have setup many many of both the engines, I try to get the people using mine to run a 4 to 5 pitch prop, Do not run high pitch props, as you will be flirting with a lot of runaway possiblity.  pitch is just too much.
A 12.5 x 4.5 2 blade is a good prop for either motor, or you can go down to a 12 inch wide blade prop at 4 or so pitch.
The 12.25 x 4.5 2 blade Mgic and Bolly works well  as does the 12 x 4.33  3 blade Magic.
The FSR has a lot of clone motors that have the exact mounting,Royal and The Taiwan built Magnums. The SF  is a little wider and is a little heavier.
Please do NOT  try to cut away the compression from the head to tame the motor, just use a larger load prop with lower pitch.
I have these all over the country running, you maybe able to see a few near you, or ask
Other people go on bout them needing a ' close ' muffler . Rather than a big one . Tho I mave use a big T&L tube on the Sf no sweat . perhaps .
The weenie C S C / Bob hunt Genisis  FSR .40  tounge goes onem BOTH as the SF is dual bolt pattern on the Ex stack .
Re: os 46fs
« Reply #9 on: November 08, 2024, 06:54:45 PM »
I got the engine tonight and it is an fx 45 not fs.The man who gave it to me flies electric not glow. He said it was way more motor than he needed. It has not been modified it is a stock rc motor. I will put a venturi and needle valve on it and see what it does. I think .300 should work. I would like to hear any suggestions.  George
Re: os 46fs
« Reply #10 on: November 08, 2024, 07:45:08 PM »
I got the engine tonight and it is an fx 45 not fs. The man who gave it to me flies electric not glow. He said it was way more motor than he needed. It has not been modified it is a stock rc motor. I will put a venturi and needle valve on it and see what it does. I think .300 should work. I would like to hear any suggestions.  George
If it is an OS46FX I have used one for stunt but I don't recommend it.  It is extremely powerful but the comfort range is very narrow.  Swapped with an OS46LA the lap times on a plane drilled for both went from 5.5 to 4.1 each running a fast 4.  The plane was 55 oz.  If you have something i the 70oz+ it may be usable.  If you can find someone with a 46AX they might be able to help you tame it.  Mine was lost in a fire.  I was going to get a curved header and put it on a pipe but never got to.
Re: os 46fs
« Reply #11 on: November 08, 2024, 08:45:27 PM »
     .300 is on the very large end of the reasonable range with an ST or other 4mm spraybar. I think you should start with something much smaller, maybe .270-.275. A stock 40VF runs with 265 with an ST spraybar if it is in good shape.
    Using a stock OS 20-46 3.5 mm spraybar, I would go even smaller, .255-.260, depending on the size of the airplane. I haven't seen anyone run an FX, but if it is as strong as a SF or better, it is WAY more powerful than a 46LA and keeping the speed in control on almost any common 40-60 sized stunt plane will be a challenge. I think it is much better to start on the small size and work up if necessary, rather than start on (or beyond) the large end and work down.
Re: os 46fs
« Reply #12 on: November 09, 2024, 12:25:47 PM »
Thankyou for the information. I will get a .260 intake and os nva and see what it does. I willtry a 12x4 for a start.  George
Re: os 46fs
« Reply #13 on: November 09, 2024, 02:25:37 PM »
If you make any headway with this, I'd sure like to hear about your experiences. Prop, plug, fuel, venturi, cowling, head clearance, etc.
Here's to success!
Re: os 46fs
« Reply #14 on: November 10, 2024, 02:57:27 PM »
After cleaning out the crankcase of rusty oil residue oiled up the bearings and put it on the test stand. I used the rc carb locked wide open a 12x4 wood zinger prop 10/18 s&w fuel. I was somewhat disappointed with the results. 9300 was about all it could do. It had little compression right after the run and the crank has a bit more up and down movement than should be. The bearings now sound rough. I don't know if the cost of the bearings and a venturi will be a good choice . I will keep you posted.  George
Re: os 46fs
« Reply #15 on: November 10, 2024, 03:37:57 PM »
     That sounds way off and the lack of compression is concerning. A Zinger 12-4 is a terrible prop, but I would have expected much more. I presume that this is an FX, not an FX-H (ringed)
   I am not sure what your plan might be, but:
https://www.ebay.com/itm/315639999725?_skw=os+46fx+piston&itmmeta=01JCC3C826TSHDG2SVHM24B37T&hash=item497d9c2ced:g:-Z0AAOSw~L1mLspN&itmprp=enc%3AAQAJAAAA0HoV3kP08IDx%2BKZ9MfhVJKkPtTiBs%2Fc%2B%2Fd1DBuILhcu%2BGP0xHoL5RdIinanmok06%2BI0mLCQo92Siff10dTHMnOcksEkbjWCmhtGvo7Bz3HHnSc4dIJWz1JdI%2Fd9Py8ZxJ2mVLxY7goCYXgKQ11TXXI14OLz3BG7FcwA4%2FXP%2FxzHSorxjCfllUFPNdIVhcsBhxvcGPzrxoq7XkVP6OOrlHvIIVCK%2FWHWipynspVxbbkHe4hlWfuCk%2BPmVWUTeGTO4hT9PwqnDHSKsyTnWD7%2BWqOU%3D%7Ctkp%3ABk9SR5qBsYPjZA
      Bearings are relatively inexpensive.
     If it is an FX-H (helicopter), it appears to be ringed, not a proper ABN. In that case, completely disassembling it, crock-potting it should be able to clean it back to bare metal, particularly the ring groove and ring, which may restore the compression.
p.s. what sort of airplane are you going to put this engine in?  Running properly, this engine is far too much to be putting in your typical 35-sized airplane.
« Last Edit: November 10, 2024, 05:36:49 PM by Brett Buck »
Re: os 46fs
« Reply #16 on: November 10, 2024, 04:43:39 PM »
Probably not your issue but my FX had a misaligned head when I got it off of the bay. It had not been torqued in the right order and was causing a slight rub at TDC.  When it ran this way I was only able to get about what you were getting.  Once corrected if revved up fine.  It was not the -H version.  None of my OS motors had much compression after a run.  I thought it was normal.
Re: os 46fs
« Reply #17 on: November 10, 2024, 06:29:57 PM »
 I took the head off and found the liner has peeled a great deal of the plating off. This motor had an extension on the muffler two baffles and only a 3/16 opening in the stinge I was planning on using it on a profile  about 58 oz and 600 sq.  George
Re: os 46fs
« Reply #18 on: November 10, 2024, 08:44:08 PM »
Sounds like its JUNK , but strip it for spares . The Rod & parts - screw set . a lot interchange .
BUt the SF is just about the same , the 15 % gives it the tourque for the big prop - 12 x 6 ,
and keeps the fire alight , rich , Enya 3 plug . with the big intake . on a big plane .
Using the .312 on the P 51 & Spitfire . Around 65 / 70 ounce . on 10 % . 4 - 2 run . use the 11 1/2 x 5 1/2 three blade too .
Runnig rotten rust thru it will do a liner in sharply , on the old 40 FP too . from poor storage . A LA 46 liner would take it to a 51
but then the head would be 1 m.m. too small .
11/20 :
Just got another one . A Megatech .46 , which is ABC and apparently ? all the ' sticker on the boost ' ones are made by LEO . if theyre not Taiwanese . ? As in you can see the BRASS .
THIS is mega glued , mega rotten bearings . Ex R. C. snot thrown on shelf unoiled after nitro . May have to cut case in half to get the liner out . Or will try slotting a penny washer 7
lifting liner by that , underneath .
« Last Edit: November 19, 2024, 10:09:21 PM by Scientifiction . »
Re: os 46fs
« Reply #19 on: December 12, 2024, 12:53:35 PM »
I have obtained new bearings and piston cylinder and rod from Bob Brooks. I got it running in 28 degree weather. It was running 11350 when first started with an 11.5 4 apc prop. I opened the needle a couple clicks and it slowed to10400 on the edge of 2 to four stroke. The intake is too large but it was what i could get at the time .315 with a .160 enya needle valve . I will run it once more on the stand and then put it in the air weather permitting.  George
Re: os 46fs
« Reply #20 on: December 12, 2024, 06:44:43 PM »
If you have a Master 12 x 6 wood , try it .
Ive thinned & trimmed a 13 x 5 to 12 inch . Has a bit of blade for the hot weather , but theyre not going to take a knock , at 2/3rd hickness .
But swings it easy . Youd get that in a deep 4 stroke , with a bit of nitro & a enya 3 plug .  say 2 stroking in the upper circle .they switch well .
.312 is the hunt FSR 40 Genisis ntake bore . So its not oversize on the .46 . One thing some said - a 1 inch tall , over case , intake gives a
more stable run .
