  • June 18, 2025, 01:20:20 PM
Author Topic: OS 45 FSR  (Read 1422 times)
Offline Mark OReilly
OS 45 FSR
« on: August 03, 2018, 08:06:37 AM »
Hi guys
Thinking of gettin back into c/l.
Is it possable to convert a OS .45 FSR for stunt use?
If so , how? What & where do i buy parts - venture, needle etc
Cheers
Mark
Re: OS 45 FSR
« Reply #1 on: August 03, 2018, 10:14:37 AM »
Hi guys
Cheers
Mark
Yes they make good stunt motors setup correctly ,  I have most all parts for them  The  PA  NVA  is  the  BEST  but I also have  real OS  FSR  NVAs
Re: OS 45 FSR
« Reply #2 on: August 03, 2018, 08:22:06 PM »
Theres that  there 40 FSR - S . ( W/C Numero Uno , in the Genisis  back then )
Jim Casale & others ran them , around 1980 . Usually with a toungue muffler .
When my copy of Bob's Toungue fell off , it seemed a lot quieter .  ;D :o :o
Most seem to have used say a 12 x 6 ( or 13 , maybe trimmed  )
Find my clone ( magnum ) happy on a 12 x 4 Bolly 3 blade .
Bob Baron ran a 45 FSR in a L J Patternmaster . 63 span - 630 Sq In . ( Jose Modesto info . )
A  lot say more powerfull than ST 60 , but dont ' back off ' downhill . Tho some say that of the ST 60 . Fine Pitch seems the go , there .
CASE is reversable . for Exhaust outer side . turn the liner & piston 180 degrees , and pull rod , clean pin , refit so the chamfer still goes
against the crank web / pin radius .
FUEL TANK wants to be 1/8 inch LOW , to get even run , insides & outsides , upright  & inverted . Can have it so it'll speed a tick on outsides though , for better tension . Back Then .
IF YOU DONT , Itll SPEED UP .  DONT use a Small Bore tank feed pipe EITHER . Wants 2 mm bore .
Theres a ABC ( normally the chrome - nickle is shot ) and a Ringed . So Use GOOD FUEL . Nelson once did P/L set ups , for the 40 S at least .
Chromed Bore - Dykes Ringed , I think .
 :P
Venturie interchangeable with the olde max 40 - S .
« Last Edit: August 03, 2018, 08:47:30 PM by Matt Spencer »
Re: OS 45 FSR
« Reply #3 on: August 03, 2018, 08:51:29 PM »
Copy of the Hunt / C.S.C. not so muffler .
brings us to , be bleedy carefull with the itty bitty muffler screws . Or youll be taping them out to 4 B.A. or 6-32 . Like This .
Tags: os 45 fsr
