Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 21, 2025, 04:45:19 AM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
OS 40 LAS or Magnum 36
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: OS 40 LAS or Magnum 36 (Read 1059 times)
Leester
2014 Supporters
Trade Count:
0
Admiral
on:
August 26, 2007, 08:16:45 AM »
I have a plane that calls for 40-46 engines with the LAS 40 recommended. Would the stock Magnum 36 be an option ? This is just for fun flying.
Logged
Leester
ama 830538
phil c
21 supporter
Trade Count:
0
Admiral
Re: OS 40 LAS or Magnum 36
Reply #1 on:
August 26, 2007, 11:06:16 AM »
I've only run one Mag 36, so I don't know how variable they can be, but out of the box it is an excellent engine. Mine is a bit better than an LA 40 in terms of being easy to set up and running more consistently and being able to turn at bit bigger prop. I run the Magnum on the stock muffler and fitted it with an LA 40 RC carb to make adjusting the venturi size easy. If you can only get one engine, get the Magnum.
Logged
Bill Little
2017
Trade Count:
0
Admiral
Second in COMMAND
Reply #2 on:
August 26, 2007, 04:49:44 PM »
Hi Lee,
Personally, I found the Magnum 36 to have more usuable power than the LA 40.
Logged
Big Bear
AMA 95351 (got one of my old numbers back!
Jerry Bohn
ACE
Trade Count:
0
Commander
Reply #3 on:
August 26, 2007, 08:26:48 PM »
If you don't wish to add, subtract, or order parts etc.for a Magnum.36, I'd suggest an OS.46LAS.
I think you would be happier with the OS.46LA, the Mag.36, the OS.40LA. in that order.
What plane are you planning to use the engine on?
Logged
Jerry Bohn
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Engine basics
Engine set up tips
(Moderator:
RandySmith
