  • June 15, 2025, 05:45:13 AM
Author Topic: LA 46 break in prop  (Read 1461 times)
Offline Bootlegger
LA 46 break in prop
« on: March 14, 2020, 01:06:25 PM »
 Guy's what prop would you recommend for an L A 46  Brian Gardener gut's I plan to run 10/22 fuel in it as he
suggested, but need/want prop dia and pitch suggestions thanks a lot...
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline frank mccune
Re: LA 46 break in prop
« Reply #1 on: March 14, 2020, 01:28:46 PM »
           Hi:
           I used an 11-3 wooden prop on my BG HP .40 piston and cylinder.  Remember to run it fast and wet.  Do not run it cold.  Did you receive Instructions with your p&c?
           Mr. Gardner made it very clear to me, do not use any castor oil in his p&c!  He suggested 20% synthetic and no nitro! Thus far, my engine has run perfectly and still makes a very loud noise when passing over tdc.
          For information, e mail Mr. Gardner as he give you the straight scoop re his products.  He is a good person.
        Good luck,
        Frank McCune
« Reply #2 on: March 17, 2020, 03:15:19 PM »
Anything that a little lighter load than your flight prop 10-4 or 9-6 is good. 10/22 is just fine. You want it running in a two stroke but breaking 4 stroke every few seconds.
Motorman 8)
Golly, I didn't realize Motorman had a Brian Gardner ABC OS .46LA. I'm interested in your findings, Motorman!  D>K Steve
« Reply #3 on: March 18, 2020, 10:09:06 PM »
11 x 4      11 x  3   will work fine Run in rich 2 cycle  2 to 3 minutes at a time, let cool  run again
Online Perry Rose
« Reply #4 on: March 19, 2020, 05:58:23 AM »
Pick one with no blood on  it.
Offline Bootlegger
« Reply #5 on: March 19, 2020, 07:13:43 AM »
  Perry, that is a good answer, but all of my used props have BLOOD on them!!!
Gil Causey
AMA# 6964
