  • August 01, 2025, 10:13:27 PM
Author Topic: OS .35 Stunt with chromed cylinder. oil reccommendations??  (Read 893 times)
Offline frank mccune
« on: June 06, 2018, 01:01:48 PM »
     Hi All:
      What type and what percentage of oil would be a good mix for the above engine.  The engine will be used for stunt and sport flying exclusively.
      Suggestion and/or comments?
        Be well,
        Frank McCune
Online RandySmith
Re: OS .35 Stunt with chromed cylinder. oil reccommendations??
« Reply #1 on: June 06, 2018, 03:33:01 PM »
     Hi All:
        Be well,
        Frank McCune
OS 35 stunt  as in  OS 35S  or  in  OS 35 FP stunt?
If OS 35S you should run 28% oil half castor, be  VERY careful you can tear out the  TINY wrist pin boss easy if it is fitted  too tight
