  • June 14, 2025, 09:48:08 PM
Author Topic: 3 Blade Props?  (Read 2401 times)
Offline Joe Messinger
3 Blade Props?
« on: September 16, 2006, 10:56:08 AM »
Hello,
I know that many of the top fliers use 3 blade props on their stunt planes.  Being that I've only been back at c/l (from the 60's) for a few years now, as always, I'm curious as to the reason(s) for such things.
Perhaps someone could explain the advantages of a 3 blade prop.  More thrust? Downhill braking?
Also, is there a point in the weight of a plane that those above that point  perform better with a 3 blade?  I do remember using 3's on 1/2 A planes.
 I know 3 blades are more expensive and I haven't seen very many offered by different prop makers.  Carbon fiber 3's are what I've mostly seen on the competition planes and those are pretty pricey.
Would there be any advantage to using a 3 blade on a sport/competition plane such as a Cardinal or Score?  How about  a Vector 40?
Thanks in advance for any information and opinions.
Joe
Joe Messinger
Offline wmiii
Re: 3 Blade Props?
« Reply #1 on: September 16, 2006, 12:04:59 PM »
 Sometimes it's just a matter of engine size and available prop clearance. I've been told that a 3blade has a different corner feel.
My own experience on a couple planes was that I could control the corner exit better with a 3 blade.
 Walter
walter menges
Re: 3 Blade Props?
« Reply #2 on: September 16, 2006, 01:27:43 PM »
Hello,
Joe
HI Joe
Yes many times there is a very big difference in performance, typically the 3 blades  have  less precession , than 2 blades, they load the engine better sometimes and are quieter. Other times they wind up less in the wind and also give a more constant speed to the model. You also can use more blade area without  having more ground clearance
This is not always the case, as there is no magic to just bolting on a prop, and you can at other times make the 2 blades work just as well or better. It s just another  important tool we have to make the planes performance much better.
Re: 3 Blade Props?
« Reply #3 on: September 18, 2006, 09:56:06 PM »
The biggest thing is that the 3 blade runs smoother.  Each prop blade hits its max angle of attack once per revolution(P effect).  On a two blade prop one blades hits max and the other hits min at the same time, twisting the prop sideways.  The difference is pretty noticeable on most planes.
Re: 3 Blade Props?
« Reply #4 on: September 18, 2006, 10:52:06 PM »
Could anyone recommend a 3 blade composite prop for a S.T. .51 on a Score?
Maybe an APC 3 blade?
Joe
Joe Messinger
Offline wmiii
Re: 3 Blade Props?
« Reply #5 on: September 18, 2006, 11:25:19 PM »
 I don't know anything about APC's, I ran a Bolly 9.5x 6.25, 3blade on a ST.46, with excellant results, saw people run the very same propellor
on ST.60's, might work on the .51.
 Walter
walter menges
Re: 3 Blade Props?
« Reply #6 on: September 19, 2006, 12:44:06 PM »
Joe
The BOLLY 12 x 6.5n   or  11.5 x 6.5  3  blades  work  very well on that  engine
Re: 3 Blade Props?
« Reply #7 on: September 21, 2006, 12:25:55 PM »
I noticed that the new plane I'm flying had a slight hunting problem. Hmm, that it's accurate. It would groove fine for a lap or two but if it hit a disturbance (turbulence, wind, whatever), it would hunt around a bit for maybe a half lap before it settled back into a groove. I changed from a Bolly 11.25x4 (pitched to about 4.25) two blade to an 11x4N Bolly three blade. The problem went away and the corners are still quite good.
Re: 3 Blade Props?
« Reply #8 on: September 21, 2006, 06:26:03 PM »
I agree with Randy's Bolly 3 blade suggestions.
But I was running a 4-3/4 pitch (repitched 12-4) Bolly 3 blade on my ST 51 trimmed to just under 12", on my USA-1.  Had an awesome run, and pulled great in all the right spots.  It was running a 4-2, but more like a PA in rpm.
Bill <><
Offline Ward Van Duzer
Re: 3 Blade Props?
« Reply #9 on: September 26, 2006, 11:35:39 AM »
What's going on here? I use a 12 X 4 N Bolly cut down to 11 1/4 on my Aero Tiger .36?????
Re: 3 Blade Props?
« Reply #10 on: September 26, 2006, 04:46:58 PM »
Hi Ward,
I liked the smaller disc area of the cut down prop.  And it worked real good.........
I haven't tried an 11 1/4 3 blade on my Aero Tiger 36.
Bill <><
