  • June 22, 2025, 09:23:34 PM
Author Topic: Prop Shaft Extensions  (Read 1170 times)
Offline David Ruff
« on: May 01, 2015, 06:20:09 AM »
Looking for proper prop shaft extensions for Enya 30-45 and OS 40-46 engines.
My Ares shows a Brodak 40 with a 3/4 in prop extension
I am planning to use an Enya or OS 40 engine.
Anybody know the proper threads for these?
Retired Army
Offline David Fountain
Re: Prop Shaft Extensions
« Reply #1 on: May 01, 2015, 06:44:48 AM »
1/4-28 on the crankshaft stud for the OS and I'm pretty certain the enya as well (David)
If it ain't broke, Don't Fix It!!
Offline frank mccune
« Reply #2 on: May 01, 2015, 07:34:52 AM »
    Hi David:
    It would be a good idea to check on the Enya threads! All of my Enya engines have metric threads that range from 6mm to 7mm.  Perhaps the more modern Enyas have converted to the S.A.E. thread form.
        See you Sunday,
        Frank McCune
Offline Steve Thomas
« Reply #3 on: May 01, 2015, 04:45:42 PM »
If you're looking at one of the more modern Enyas (eg SS30/35/40) then it's 1/4-28.  For something like an old 35-III or 45-I, you need 7mm.
Offline David Ruff
« Reply #4 on: May 02, 2015, 04:12:22 AM »
Steve; they are all new mfg engines, so if your 1/4 -28 is correct, then I should be good to go.
Thanks much
Retired Army
